Dog Sow Boradband
- Re: Dog Sow Boradband
Dog Sow Boradband
29-03-2014 2:51 PM
I am continuing to get periods of very poor boadband speeds.
Can you check my line and see what is happeniong.
Jacobyte
Jacobyte
Message 1 of 7
(1,360 Views)
6 REPLIES 6
29-03-2014 2:55 PM
Can you post up your router stats (there is a link at the top of this forum how to get them) ?
Message 2 of 7
(676 Views)
29-03-2014 3:05 PM
Line Status:Connected
Dsl up time:3 day(s) 08:39:03
DSL Modulation Type:ADSL_G.dmt
Annex Type:Annex A/I/J/L/M
Upstream Downstream
Current Rate (Kbps) 448 8128
Max Rate (Kbps) 1096 10592
SNR Margin (dB) 23 11.5
Line Attenuation (dB) 10.5 17.5
Occupancy (%) 40 76
Errors (Pkts) 0 0
Upstream Downstream
Occupancy (%) 40 76
Errors (Pkts) 0 0
Message 3 of 7
(676 Views)
29-03-2014 3:08 PM
Hmm doesn't look too shabby.
Does the issue happen on both wireless and wired connections ? Sometimes there can be wireless interference which causes slower speeds and it is worth ruling that out if possible before trying to chase faults with your broadband connection itself.
Message 4 of 7
(676 Views)
29-03-2014 3:14 PM
I do not have any wired connections to compare as my desktop PC is not close to the Router.
J.
Message 5 of 7
(676 Views)
30-03-2014 5:30 PM
Unfortunately it will be difficult to raise a fault without speedtests over a wired connection and preferably on the test socket to rule out internal wiring issues. Wireless connections are very easily susceptible to interference and speed drops.
I appreciate you may not have seen speed drops before but anything can cause speed drops on wireless, walls, fridge motors, microwaves, cordless phones, a neighbour getting a new router on the same channel as yours to name but a few!
Message 6 of 7
(676 Views)
31-03-2014 2:16 PM
Hi J,
I've checked over your connection and can't everything looks OK, are you achieving around 7Mb/s at all as I noticed you said it's slow at only certain periods.
Message 7 of 7
(676 Views)
