Does anyone use a Netgear DG834G router?
- Does anyone use a Netgear DG834G router?
11-05-2009 1:44 PM
Does anyone have any ideas as to what might be the problem?
Re: Does anyone use a Netgear DG834G router?
11-05-2009 1:55 PM
What happens if you try going to http://192.168.0.1/
Does it ask you for a username and password?
11-05-2009 1:56 PM
11-05-2009 2:02 PM
11-05-2009 2:05 PM
user - admin
password - password
Once you have done that you need to set it up for your Plusnet username and password under Basic Settings - alternatively you can use the Setup Wizard at the top of the page
11-05-2009 2:09 PM
Thanks for your time just now.
As I mentioned, I think the best bet is to try setting up the router manually, rather than trying to use the wizard.
http://www.plus.net/support/broadband/help_and_setup/general_setup_guide.shtml
That's the link I mentioned.
Most importantly:
* Data Circuit Information: VPI = 0 (Virtual Path Identifier) VCI = 38 (Virtual Channel Identifier)
* Data Link Encapsulation: PPPoA
* PPP Properties: VC Multiplexed
And you need to make sure that you're putting in your username in the format of username@plusdsl.net
Let me know if you have any further problems.
11-05-2009 2:44 PM
These are the pages I get when after I use the setup wizard, can you see anything that's not right?
11-05-2009 3:19 PM
It's obviously sync'ed so it's just that final bit of authentication that's wrong.
Unless you're on a static IP or BT have misconfigured the line.
11-05-2009 3:29 PM
It's definitely your password that is incorrect.
I can rejections on our servers, as well as your router saying that it's a password problem (CHAP authentication failure).
11-05-2009 3:32 PM
What is the username and password do you type in here https://portal.plus.net/index_nlp.html?home=membercentretop to access your account details?
The username from above needs to be put into the router as username@plusdsl.net
SW.
3Mb FTTC
11-05-2009 3:33 PM
11-05-2009 3:50 PM
11-05-2009 3:51 PM
