Does PN throttle speed in evenings?
FIXED- Subscribe to RSS Feed
- Re: Does PN throttle speed in evenings?
10-06-2016 8:45 PM
I'm synched at about 19 meg and download speed for the last couple of hours has been between 4 and 5 meg. Upload is fine but download is pretty bad.
I've used a couple of different speedtest apps. and the results are literally the same.
Fixed! Go to the fix.
10-06-2016 9:37 PM
10-06-2016 10:36 PM - edited 10-06-2016 10:36 PM
11-06-2016 9:50 AM
To answer your question, no we don't. It is possible that your exchange is congested at peak times though, if you continue to see slow speeds at certain times I'd advise getting this reported in to us at https://faults.plus.net
11-06-2016 12:36 PM
Thanks Chris. And yes, you're probably right about the congestion. Thankfully it didn't last for long and everything was back to normal quite quickly.
