Dodgy Thomson Router?
- Dodgy Thomson Router?
21-07-2012 8:47 AM
I select troubleshoot problems option when I appear to have lost connection, it goes through all the tests and always comes back with turn off power to router for 10 seconds and turn on again, which does seem to fix it.
Any ideas what causes this, is the router playing up?
Re: Dodgy Thomson Router?
21-07-2012 9:34 AM
http://usertools.plus.net/status/archive/1342815674.htm
http://usertools.plus.net/status/archive/1342644016.htm
http://usertools.plus.net/status/archive/1342621062.htm
are some examples.
However, when you said you select the "Troubleshoot problems option" what are you actually using - if on-line can you provide a link?
Does this option at any time suggest you try a Disconnect and then Connect of your PPP Internet session - see here for example. In the Internet area, the clickable button is on the right. This should always be tried first in preference to powering off.
(I did recently criticise the suggestion of unnecessary power downs / reboots here
If you also post your DSL stats (see the box in the link above) click on View more .... and copy and paste the results in a post and we can see if there is anything obviously wrong.
21-07-2012 1:22 PM
Unfortunately I cannot remember exactly the wording it provides to resolve problem other than disconnect and reconnect router.
Here are my DSL Connection stats
DSL Connection
Link Information
Uptime: 0 days, 4:50:26
DSL Type: G.992.5 annex A
Bandwidth (Up/Down) [kbps/kbps]: 1,195 / 20,699
21-07-2012 2:55 PM
If the network icon is showing that there is a problem, right click and select repair. If that doesn't work, open your browser and type in the modem/router address and login (if it's a Thomson, which it looks as though it is) see section 4 of the link I posted. I guess you may have already done that to try and get the stats.
Do Disconnect and then Connect, If it doesn't solve the issue, do a Disconnect and then/or if for some reason the modem/router has locked up and won't respond at all, rather than just reboot, a more graceful way is to pull the mains power plug. Then wait a few minutes (make a tea/coffee etc). then power up again. (You may need to login to the modem/router and click Connect if you Disconnected before).
As for the stats, you've only got the top few details there (remember to click View more....). The bits we need to see include Noise Margins and Attenuation and Error figures.
21-07-2012 3:31 PM
Or it could be the connection between the router and your computer that gets dropped and not re-established (until the router is re-started). The root cause of such a problem is not necessarily the router so if that is your problem then you cannot be certain that the router is at fault.
By way of an example, the wired connection between my desktop computer and my Netgear router occasionally hangs. But I can still connect wirelessly to the router from my laptop and the router is still connected to the internet. The cure to this problem is to restart the router; re-starting the computer does not work. I presume the router is at fault although it's difficult to be absolutely sure. And although the problem manifests as an inability to connect to the internet, it is really the connection to the router that has gone wrong.
21-07-2012 4:08 PM
21-07-2012 4:21 PM
Does this help?
I haven't been rebooting my router, just disconnect from mains each time and seems to cure it until next time..
DSL Connection
Link Information
Uptime: 0 days, 0:18:07
Bandwidth (Up/Down) [kbps/kbps]: 1,159 / 20,699
Output Power (Up/Down) [dBm]: 11.5 / 0.0
Line Attenuation (Up/Down) [dB]: 6.5 / 13.5
SN Margin (Up/Down) [dB]: 7.0 / 3.5
Loss of Link (Remote): 0
FEC Errors (Up/Down): 4,294,967,264 / 0
CRC Errors (Up/Down): 4,294,967,264 / 0
HEC Errors (Up/Down): 0 / 0
21-07-2012 4:59 PM
The stats - well you must be almost next door to the exchange with that line attenuation, but I'd expect a much better downstream noise (SN) margin under those circumstances, and consequentially the sync speed is down a small amount.
This suggest you have a noise problem which could be causing issues. I notice the uptime is only 18minutes 7sconds there, do you switch off the modem/router when you aren't using it, or did you have to do a power down again?
Did you try logging in and Disconnecting and the Connecting again?
Tell us a bit about your installation. Do you have any fixed extension sockets and wiring? Are you using any extension leads? Are you connected via Ethernet or Wireless? Do you have a corded or cordless phone, sky box etc. Describe briefly how things are connected. Is it a v7 or v8 585, does it have the latest firmware?
When using the phone, can your hear any crackling or other noises on the line? Do you have any problems with outgoing or incoming calls, all which may indicate a problem with the line?
21-07-2012 5:09 PM
Quote from: Richchad I have to power off my PN Thomson router every few days as I loose internet connection.
Quote from: Anotherone As we don't yet now whether or not he can re-establish an Internet session form the router interface, imply restarting the modem/router willy nilly should be the option is poor advice
I didn't imply that, Anotherone, or are you referring to the Windows 7 troubleshooter? As we are both aware, one reason why you don't just restart the router is because you then lose any information you might have obtained about what caused the problem. Indeed repeated restarts can harm your internet connection but once every few days should not give rise to any problems.
21-07-2012 5:30 PM
PC runs all day and has gone into sleep mode sometimes but that shouldn't effect router...
I am running on Ethernet and have a fixed socket in hall with extension running ADSL only to office adjacent.
I have cordless phones and Sky but the ADSL is separated from phone line.
Thomson is v7 585.
21-07-2012 6:48 PM
If you are running ADSL only to the office, does that mean you have a faceplate like the one here on the RHS or one similar to this NTE-2005?
Is the cable going to this office like this?
Could you advise about listening to the phone line? If necessary do the quiet line test on 17070 option 2.
21-07-2012 7:11 PM
The cable is Telephone Cable CW1308 running from terminals in faceplate to a RJ45 extension box from Clarity, with a Ethernet lead plugged into box and router.
Have checked phone line quiet test, all good.
21-07-2012 8:16 PM
A few things to try, which ever you find easiest first. Stop the computer going into sleep mode just in case this is causing some issue, see if the problem continues. Another thought do you use the wireless connection? If not, is it turned off, turn it off if it isn't. Have you started using any new wireless n devices recently? Is the wireless connection secure?
Do you have an alternative modem/router to try, also a spare rat's tail filter. This sort of testing is always a bit of a pain in the butt. If none of the above make any difference, easiest thing would be to try another modem/router to see if the problems continue because it is beginning to sound like it could be the 585 having problems.
If you don't have a spare modem/router the next test (having done a disconnect and powered down) would be to remove the faceplate and plug in a rat's tail filter to the test socket and your modem/router into the filter. Don't use any extension leads between the test socket and filter or filter and modem/router. You'll have to leave it for at least overnight, preferably longer if you weren't seeing disconnects that often. The thing to check is the uptime on the stats.
22-07-2012 6:37 AM
I may try the options you suggest as unfortunately I don't have a spare router although I am considering buying one now.
The Thomson was a freeby from PN in 2009 so maybe I will look for a better router such as maybe one from Netgear...
Thanks for your help, will see how it goes.
22-07-2012 7:40 AM
