Do want to use a BT Homehub 3 or 2 on Plusnet ADSL or FTTC?
- Do want to use a BT Homehub 3 or 2 on Plusnet ADSL...
Re: Do want to use a BT Homehub 3 or 2 on Plusnet ADSL or FTTC?
08-01-2014 9:19 PM
All the details I know are below in the image.
08-01-2014 9:38 PM
09-01-2014 10:01 AM
Quote BT Home Hub 4 (Type A) | Software version 4.7.5.1.83.8.130.1.17 | Last updated 07/01/14
09-01-2014 1:22 PM
I wondered if you could help. I have the Home Hub 5 all setup and everything seems to be going fine apart from one slight issue. When I am using my iPad, it appears that it keeps swapping between the the 5GHz & 2.4GHz bands. This then stops videos from streaming and web pages loading. The only way around it is to turn the wifi off on the iPad and then back on again.
Is this a known issue, and is there a solution for it?
Thanks for any help
EDIT: So I have just been reading up on this issue, and if I am understanding it correct the issue is coming from there only being one SSID for both bands. So the device is connecting to both, which some devices don't like. So I am going to rename the 5GHz one, but what I was wondering is it better to connect to the 2.4 or 5GHz band?
09-01-2014 2:06 PM
Edit: It's actually further up this page: http://community.plus.net/forum/index.php/topic,113872.msg1058551.html#msg1058551
09-01-2014 2:12 PM
09-01-2014 2:17 PM
10-01-2014 10:46 AM
All I can get is this:-
Connection time: 2 days, 11:14:39
Downstream: 9.364 Mbps
Upstream: 938 Kbps
10-01-2014 1:33 PM
http://forums.thinkbroadband.com/bt/4259838-home-hub-4-line-stats.html#Post4259866
11-01-2014 10:03 AM
Got this
19:37:51, 10 Jan. (245343.630000) DSL noise margin: 5.50 dB upstream, 3.00 dB downstream
11-01-2014 5:47 PM
There has been some family issues that i've had to sort out
@ScottJames I hope separating the SSID's worked as the clashed SSID has been a known error to BT and haven't made changes on the hubs.
10-10-2014 2:59 PM
I did the reset as instructed (done it again since as well!), but it shows the BT Wifi status as active. I have turned both Wifi bands off so I can only assume that it is the hotspot that is active.
Is there any other way of turning it off?
11-10-2014 12:44 PM
Is there other hubs around you? Are your neighbours using a BT hub?
11-10-2014 7:07 PM
I am a little confused by it though - the hub reports BT Wi-fi Status as Active but I can't now see any sign of it on my phone!
22-10-2014 6:49 PM
In the meantime - if it bothers you - reset the hub and it should go off
