Do want to use a BT Homehub 3 or 2 on Plusnet ADSL or FTTC?
- Do want to use a BT Homehub 3 or 2 on Plusnet ADSL...
Re: Do want to use a BT Homehub 3 or 2 on Plusnet ADSL or FTTC?
10-04-2013 9:48 AM
10-04-2013 5:02 PM
Quote from: Finguz Initially we replaced the 582 with a home hub 3, but it can't be configured to respond to ping from wan, breaking BQM, so has been shelved.
Plusnet have advised that user attempts to edit the article are likely to be - at best - troublesome so it will be down to me to complete it. I tried to add to it this afternoon but it wouldn't play ball. It does that from time to time but I'll have another go later.
10-04-2013 7:18 PM
Don't have one, would like one to test but so far freecycle has come up empty.
10-04-2013 7:31 PM
Feel free to copy the whole steps I have added as an Author. But please can you consider me as a Contributor since I made the thread and post.
10-04-2013 8:07 PM
Are you able to confirm that the settings options don't allow ping responder to be enabled from the WAN?
David
10-04-2013 8:17 PM
10-04-2013 11:13 PM
In fact the Thinkbroadband Broadband Quality Monitor router set-up guide says BT Homehubs aren't supported so that confirms it.
10-04-2013 11:21 PM
I am going to invest in the Asus RT series. Not the expensive ones.
10-04-2013 11:51 PM
The Asus routers get good reports in these forums so should be a good choice.
11-04-2013 9:59 AM
11-04-2013 11:32 AM
11-04-2013 11:53 AM
Would revising the "needs to be unlocked" paragraph to a "needs to be upgraded" equivalent, and quoting the firmware version required, be appropriate? I think going into obtaining and upgrading to later software is beyond the scope of the article.
11-04-2013 12:38 PM
11-04-2013 4:46 PM
11-04-2013 9:10 PM
Thanks v much SpraxyT and Bob Pullen.
Keep it up
