Do I need fibre? (not a bowel related question)
- Do I need fibre? (not a bowel related question)
Re: Do I need fibre? (not a bowel related question)
02-01-2014 3:57 PM
I don't know much about fancy TV's either, this is the first TV we've had for several years!
02-01-2014 5:14 PM
Download Speed: 7790 kbps
Streaming Speed (1): 8068 kbps
Streaming Speed (2): 8109 kbps
Streaming Speed (3): 8106 kbps
We have Plusnet Unlimited.
We've also had an SD stream over WiFi to an Android tablet running at the same time.and a large FTP download on a wired computer which just used the spare capacity. However WiFi was probably using 125Mbps at this time.
The OP is using a TG585v7 which doesn't have 'n' rated WiFi but 'g' should be more than adequate for a single HD stream. Plenty in hand if it's SD.
02-01-2014 11:05 PM
Both had a couple of brief moments of buffering and I'm syncing at 13Mbs and an iPlayer diagnostic shows loads of headroom.
03-01-2014 9:16 AM
@'DrJon' - Answering your question -
1) No you probably don't need fibre - UNLESS you intend HD streaming to multiple televisions/PCs.
2) You do need to upgrade to 'Unlimited' for the unrestricted monthly usage allowance.
3) Instead of WiFi, I would connect the TV using an ethernet cable, or homeplug mains adaptors
4) Ensure your ADSL connection is working properly.
5) ASK IN THIS THREAD for Plusnet to have your ADSL2+ upstream speed uncapped (for free).
03-01-2014 9:30 AM
I have requested an upgrade to Unlimited.
PlusNet customer support, if you are reading this thread can I please have my ADSL2+ upstream speed uncapped?
Thanks again.
03-01-2014 9:43 AM
I use iPlayer, 4OD, Demand5, Netflix and NowTV, using Roku, with a connection no faster than yours.
03-01-2014 11:40 AM
Just placed that for you, it should complete on Monday for you. Hope it helps.
15-01-2014 9:18 PM
Still having problems. Even though the above fix was attempted and I have now upgraded to Unlimited, we still cannot watch a program on iplayer because it is constantly buffering.
I'm tearing my hair out, I'm down on my knees,
Would someone from PlusNet help me please!
16-01-2014 1:08 PM
Just had a look over everything from our side. Your profiles are matching fine at 8000 which should be plenty fast enough to watch any streaming. I can't see any odd usage or any evidence that the upstream is being saturated which might interrupt things either.
Would you be able to run a BT speed test please, so we can see what kind of speeds you're getting from your side? You can find that at http://speedtest.btwholesale.com
16-01-2014 7:35 PM
Here are the BTW test results:
Download speed: 7.98mb
Upload speed: 0.96mb
Ping latency (ms): 39,00
17-01-2014 10:55 AM
17-01-2014 6:10 PM
I really hope that you can sort this otherwise I'm afraid I'll have to bid farewell to PlusNet.
17-01-2014 8:33 PM
If it can't be sorted then can you please advise me how I can leave PlusNet with minimal hassle. Unlimited broadband my a
17-01-2014 8:36 PM
The difference is that I use these: http://www.amazon.co.uk/TP-Link-TL-PA211KIT-200Mbps-Powerline-Ethernet/dp/B004INVKP4
18-01-2014 7:50 AM
So how do these things work and is the Powerline adapter easy to set up?
I'd still be curious to hear a response from PlusNet, is the problem that the supplied wireless router just isn't any good?
The confusing thing is that for a couple of days after I upgraded to Unlimited I could watch iplayer without any problems. Then suddenly it started buffering all the time again.
