Do I have a Problem?
- Re: Do I have a Problem?
07-06-2012 9:42 AM
So, is this about right or is there something I should be investigating?
Thanks in advance.
Mike
07-06-2012 9:56 AM
07-06-2012 2:07 PM
Most speedtests will be slower then normal this week.
07-06-2012 7:50 PM
this is the result of the BT Speed test
1. Best Effort Test: -provides background information.
Download Speed
4.05 Mbps
0 Mbps 7.15 Mbps
Max Achievable Speed
Download speedachieved during the test was - 4.05 Mbps
For your connection, the acceptable range of speeds is 2 Mbps-7.15 Mbps.
IP Profile for your line is - 5.98 Mbps
Upload Speed
0.34 Mbps
0 Mbps 0.45 Mbps
Upload speed achieved during the test was - 0.34Mbps
Additional Information:
Upstream Rate IP profile on your line is - 0.45 Mbps
07-06-2012 8:07 PM
Noise Margin: 6.3 dB
Connection Rate: 4391 Kbps
Line Attenuation: 50.0 dB
A bit more information here http://community.plus.net/forum/index.php/topic,96155.0.html
However your speed in the BT test is a bit low - what does this give for Current Line Speed https://portal.plus.net/my.html?action=data_transfer_speed
07-06-2012 8:43 PM
Thanks for your time tonight.
I've made some small changes to your line which I hope should provide an increase in your downstream throughput speed. Test the line again tomorrow for us and I'm tipping things should have improved
08-06-2012 7:47 AM
Just run another test and things are a lot better.
@ oldjim, the current line speed via the link you gave is
Estimated line speed:
5Mb (This may vary between 4Mb and 6Mb) - Checked on 2012-05-22 16:50:21
Current line speed:
5.9 Mb
So I would appear to be above what can be expected at the moment.
For info the router status now is:
ADSL Link Downstream Upstream
Connection Speed 6784 kbps 445 kbps
Line Attenuation 43.5 db 25.9 db
Noise Margin 11.9 db 24.2 db
dick:quote
08-06-2012 9:32 AM
Are you aware of any bursts of disconnections
Perhaps a member of staff can look at the line history
08-06-2012 10:56 AM
dick:quote
08-06-2012 11:07 AM
Download Speed
5.6 Mbps
0 Mbps 7.15 Mbps
Download speedachieved during the test was - 5.6 Mbps
Upload Speed
0.34 Mbps
0 Mbps 0.45 Mbps
08-06-2012 1:19 PM
The issue there is to do with the Attenuation - if that's over 30dB we'll usually set the downstream SNR to 9dB or even higher, rather than 6dB as it won't be stable otherwise. I suspect yours is set to 12dB because it's over 40dB, it may well not be stable if the SNR is lower than that.
08-06-2012 7:09 PM
Mike, can you post your current modem/router ADSL line stats and if there are any error figures CRC/HEC/ES/FEC/RScorrectable - that sort of thing, those as well.
08-06-2012 7:22 PM
Quote from: Matt Hi there,
@anotherone... I agree. My default margin is set to 3db, and currently is wonderfully stable. I am on 21CN ADSL2+
08-06-2012 8:52 PM
Latest router stats are attached, and there is this log in there as well:
Sat, 2012-06-02 14:48:46 - Receive NTP Reply from time-g.netgear.com
Sat, 2012-06-02 15:47:38 - Router start up
Tue, 2012-06-05 12:48:47 - Send out NTP request to time-g.netgear.com
Tue, 2012-06-05 12:48:48 - Receive NTP Reply from time-g.netgear.com
Thu, 2012-06-07 10:08:28 - TCP Packet - Source:***.***.*.*,57690 Destination:64.4.9.190,80 - [BLOCK]
Thu, 2012-06-07 20:45:06 - Initialize LCP.
Thu, 2012-06-07 20:45:06 - LCP is allowed to come up.
Thu, 2012-06-07 20:45:09 - CHAP authentication success
Fri, 2012-06-08 07:40:38 - Administrator login successful - IP:***.***.**.*
Fri, 2012-06-08 10:48:49 - Send out NTP request to time-g.netgear.com
Fri, 2012-06-08 10:50:09 - Send out NTP request to time-h.netgear.com
Fri, 2012-06-08 10:52:19 - Send out NTP request to time-g.netgear.com
Fri, 2012-06-08 10:53:36 - Administrator login successful - IP:***.***.*.*
Fri, 2012-06-08 10:56:09 - Send out NTP request to time-h.netgear.com
Fri, 2012-06-08 11:03:19 - Send out NTP request to time-g.netgear.com
Fri, 2012-06-08 11:17:09 - Send out NTP request to time-h.netgear.com
Fri, 2012-06-08 11:44:19 - Send out NTP request to time-g.netgear.com
Fri, 2012-06-08 12:38:09 - Send out NTP request to time-h.netgear.com
Fri, 2012-06-08 14:25:19 - Send out NTP request to time-g.netgear.com
Fri, 2012-06-08 17:59:10 - Send out NTP request to time-h.netgear.com
Fri, 2012-06-08 20:40:24 - Administrator login successful - IP:***.***.*.*
