Disconnections
Fixes: 21
Re: Disconnections
Yes, well why not, if you can/need to make use of it and cost isn't an issue then go for it. Just go hell for leather on any phone line issues if there are any before the change over. But if your line is not with Plusnet, it should be easier anyway when it is.
Fixes: 136
Re: Disconnections
Quote from: Anotherone
Hmm, we'll have to get a CRT person to get the Products team to have a look at yours and see whether they can "push" it to you.
This is possible but considering the problems the OP is having, I don't think it's going to help.
Fixes: 21
Re: Disconnections
Well, that is my suspicion as it's a fairly old 585, but anything worth a try as a last resort I thought Wink
