Disable ports 21/23
- Re: Disable ports 21/23
Disable ports 21/23
14-01-2016 1:29 PM
Hi we have been asked to disable ports 21 and 23 to stop inbound traffic by our card terminal provider to comply, can anybody help please
Message 1 of 9
(1,352 Views)
8 REPLIES 8
14-01-2016 1:36 PM
Traffic in to all ports should be disabled by default, this might mean that someone has already opened these port implying you have a need for them, so closing them may cause you other issues.
P.S. What exactly do you mean by 'inbound traffic'
Message 2 of 9
(964 Views)
14-01-2016 1:46 PM
well we have a cctv system on port 80 and a PC and card terminal on the router but the card terminal provider has done a security scan to ensure compliance but have found that ports 21 and 23 are insecure and need closing but I don't know how to go about it
dick:quote
dick:quote
Message 3 of 9
(964 Views)
14-01-2016 1:52 PM
which router are you using
Message 4 of 9
(964 Views)
14-01-2016 2:00 PM
hi the router is white and has router model sticker huaweihg533 regards
Dave
dick:quote
Dave
dick:quote
Message 5 of 9
(964 Views)
14-01-2016 2:23 PM
These ports 21 FTP and 23 Telnet may well be factory enabled on your router but as I do not have one of these I can't confirm this, someone will come along soon and tell you what you need to do.
Message 6 of 9
(964 Views)
14-01-2016 2:24 PM
So it is a HUAWEI HG533
Can you try checking your open ports using https://www.grc.com/x/ne.dll?bh0bkyd2
Note a quick check indicates that they should be blocked by default
Message 7 of 9
(964 Views)
14-01-2016 2:35 PM
http://portforward.com/english/routers/port_forwarding/Huawei/HG533/defaultguide.htm may help.
Call me 'w23'
Message 8 of 9
(964 Views)
14-01-2016 3:52 PM
this is also a useful check to see if a port is open http://canyouseeme.org/
Message 9 of 9
(964 Views)
