Disable DNS service on technicolor tg582n router - how?
- Re: Disable DNS service on technicolor tg582n rout...
19-12-2012 2:37 PM
I have just started up with Plusnet and have been supplied a technicolor tg582n router which current deals with the internal networks dns service. I want that handled by my network server (only for internal network-I'm not hosting a website). How do I disable the DNS service on this router?
Mark
Re: Disable DNS service on technicolor tg582n router - how?
19-12-2012 2:42 PM
19-12-2012 2:44 PM
19-12-2012 3:03 PM
If you haven't changed the router DHCP allocation range you'll probably want to give your PCs IP addresses in range 192.168.1.1 to 192.168.1.63
Edit: See Kelly's post below if you have a DHCP server on your network. My post is only correct if you haven't.
19-12-2012 3:05 PM
If you've a separate DHCP server on your network it should handle the rest.
Ex-Broadband Service Manager
19-12-2012 3:10 PM
Could you be a bit more specific as to where to find that option as I cannot see it?
Thanks,
Mark
19-12-2012 3:11 PM
19-12-2012 3:15 PM
Mark
20-12-2012 2:48 PM
Mark
20-12-2012 3:23 PM
23-01-2013 4:15 PM
