Difference in Speed test between two PCs
- Re: Difference in Speed test between two PCs
02-08-2012 3:34 PM
Something odd, and I wonder if anyone can shed light on it. I've got a BT fibre connection. The Netgear router is connected directly to a 200AV Homeplug. The next Homeplug feeds a small switch that has 3 PCs connected to it. Two of these PCs are Windows XP, and one is Mandriva Linux. Now, if I run broadband speed tests on each of the PCs (remember they're all connecting to the router via a 200AV Homeplug), the two Windows PCs report about 29Mbps. However the Linux PC reports 32Mbps.
If I plug a laptop directly into the router (bypassing the Homeplugs) I get a speedtest result of 32Mbps.
All broadband speed testers give the same result. 2-3Mbps slower on the Windows PCs. The only other difference I notice is that the Linux PC reports a Ping of 15 to the Speednet servers whereas the Windows PCs report 22.
Anyone know why this might be? I'm running a 3rd party firewall on the Windows PCs, but I get the same result on the Windows firewall (and I'm damn well not running it without!).
-Curious Dave
-Curious Dave
A tortoise? What's that?
You know what a turtle is? Same thing.
Message 1 of 3
(718 Views)
2 REPLIES 2
02-08-2012 3:44 PM
What are you using to run the speed tests? I'm just wondering if you're using a java based tester? I'm not sure why but perhaps a difference in the way Windows and Linux use Java might be a starting point for you
Message 2 of 3
(335 Views)
02-08-2012 4:16 PM
What do you have the RWIN size set to?
If you don't understand the question go to http://www.dslreports.com/tweaks and see what it recommends.
Message 3 of 3
(335 Views)
