Default Gateway
- Re: Default Gateway
Default Gateway
11-03-2014 11:15 PM
What should the default gateway be set to on a technicolor router on ADSL in the TCP/IP settings it's set to a 195.xxx.xxx.xxx address at the moment. Should it be the routers address?
Mark
Mark
Message 1 of 2
(1,099 Views)
1 REPLY 1
Re: Default Gateway
12-03-2014 1:30 AM
That is your current PlusNet gateway on to the wider internet. It is nothing to be concerned about and will automatically change if you get disconnected for some reason.
That's RPM to you!!
Message 2 of 2
(837 Views)
