Decent download but Upload speed very bad
olly66
My download speed is about 16Mb/s which is pretty decent, for ADSL, but my upload speed is less than 500kb/s.....the router shows the connection as 20Mb/s and upload as 1Mb/s. Anyway, can this be adjusted somehow by someone at Plusnet? I think I’ve read people talk about modifying a profile?Huh
TIA
olly
3 REPLIES 3
Fixes: 245
Re: Decent download but Upload speed very bad
Hi @olly66, I've tested the connection and the upstream does not appear to be capped. Testing shows the upstream is in sync at just over 1Mbps, which isn't far off the maximum capabilities of ADSL upstream. Unfortunately there wouldn't be much more we could do at this point for upstream on your account as it's already uncapped.
EDIT: Corrected would, to wouldn't
 Harry Beesley
 Plusnet Infrastructure Operations Professional
Fixes: 20
@HarryB Should the 'would' in your reply be 'wouldn't'?:wink:
Fixes: 245
Thanks @jab1, I've edited my previous reply to correct that now :thumbsup:
 Harry Beesley
