Data transfer usage upgrade
- Re: Data transfer usage upgrade
06-12-2007 7:43 PM
I have foolishly gone over my data transfer allowance in my first month with PlusNet and will not have the billing month reset until 16th December. However, I intend to use more than 8GB a month regularly so I will upgrade for the 75p more per month.
If I upgrade today, will the line speed be restored for this billing month or will restrictions continue until the 16th?
Message 1 of 7
(1,570 Views)
6 REPLIES 6
06-12-2007 7:50 PM
I think it should be - it might take a disconnect/reconnect to take effect.
Message 2 of 7
(726 Views)
07-12-2007 12:40 PM
Any PlusNet staff member able to confirm this?
Message 3 of 7
(726 Views)
07-12-2007 1:04 PM
A reboot should put you on to the usual service offer.
Have you done this yet? If so, are you still seeing slow speeds?
Message 4 of 7
(726 Views)
07-12-2007 4:25 PM
Quote from: Jameseh Hi there,
Rebooting the router will override the line speed restrictions? I've not tried that yet, I'll give it a go this evening.
Message 5 of 7
(726 Views)
07-12-2007 4:29 PM
When the policy applied to your account is changed, it sometimes isn't picked up until you disconnect and reconnect when it picks up the current settings.
Message 6 of 7
(726 Views)
07-12-2007 4:29 PM
Yup.
If our service offer has changed since your last reboot, you may need to reboot to see if it improves the situation.
Message 7 of 7
(726 Views)
