DSLAM and router chips
- DSLAM and router chips
10-07-2012 10:04 AM
Also, anyone suggest a good router for a long line of 63.5 Attenuation. I have been told of Billion 7800, 2 Wire 2700 and surprisingly the Thomson (Technicolor??) Speedtouch 585v6. Any others? Thanks.
Re: DSLAM and router chips
10-07-2012 10:36 AM
From the stats you posted earlier, you have:
System Vendor ID (Local/Remote): TMMB/----
Chipset Vendor ID (Local/Remote): BDCM/TSTC
So the hardware in the exchange is TSTC (Texas Instruments). The DG834G v3 was based on the Texas Instruments AR7 chip. But the AR7 chip (or any further developments from it) doesn't seem to be very common anymore, Texas Instruments sold it off or spun it off as a separate company. Broadcom based routers seem very common these days. It can even be difficult to buy an exact chip since some vendors seem to like changing the internal chips without changing the model number - and we ended up with 5 different types of Netgear DG834G!
10-07-2012 11:17 AM
10-07-2012 11:35 AM
10-07-2012 1:55 PM
My point regarding the 834g v3 was that it has the same chipset as my exchange. The2 routers you mention are Broadcom.
Do you think it is better to have the same chipset as the exchange? This is something mentioned frequently in router forums. As you know I have been looking to replace the 582n.
10-07-2012 3:37 PM
Broadcom do seem to have the best overall reputation for decent speed with stability.
The (now old-ish) BT Business Hub (2-wire 2700HGV or 2701HGV) have an excellent reputation for stability on long lines (not necessarily the fastest connection) and can probably be picked up on well known auction sites for a modest amount.
12-03-2013 12:56 PM
3Mb FTTC
12-03-2013 1:06 PM
12-03-2013 1:46 PM
The dg834gt router works well, but unlike the 2700hgv, it does not reallocate tones that become unusable at night, the net result is that over time the sync gradually reduces.
As i have been suffering from a known dns issue on the 2700hgv where certain url's fail to load, i have just ordered a Billion 7800n router, as it gets rave reviews for stability and sync rates it will be interesting to see how it performs here.
Might get brave and have my upload uncapped
Paul.
08-04-2013 2:33 PM
The 2700hgv would sync in the mornings at just over 3000kb/s on a 12db SNR setting. To get the 7800dxl to sync at that speed I need to tweak the SNR down to be about a 9db SNR target. It could be that the 2700hgv is just more sensitive or measures SNR in a different way, the main point though is so far it does seem to be able to maintain approximately the same speeds as the 2700hgv.
The range of the Wifi is much improved compared to the 2700hgv, in places where I use to have blackspots of Wifi coverage, I would say those are gone now.
So short term the results are encouraging.
3Mb FTTC
