DSL link keeps going down
- DSL link keeps going down
01-08-2018 10:54 PM
Re: DSL link keeps going down
02-08-2018 11:15 AM
Hi @Geoff44
There does seem to be an overly large amount of drops on you RADIUS;
Our testing is not finding any cause for this i'm afraid.
I'd recommend starting with basic checks here.
If that doesn't help the next thing would be to rule your internal wiring out by plugging the connection into your test socket which is under the faceplate of your master socket and seeing if the drops stop. This rules out internal wiring, face plates and extension sockets as being the cause.
How to locate the test socket and set your connection into it can be found here
If the problem still persists from here we will go down the route of raising a fault.
Let us know how it goes.
