DSL keeps disconnecting
- DSL keeps disconnecting
- « Previous
- 1
- 2
- Next »
Re: DSL keeps disconnecting
20-03-2014 9:42 AM
Latest stats showing abnormal SNR
Link Information
Uptime: 0 days, 0:01:48
DSL Type: ITU-T G.992.5
Bandwidth (Up/Down) [kbps/kbps]: 888 / 13.807
Data Transferred (Sent/Received) [MB/MB]: 252,09 / 237,94
Output Power (Up/Down) [dBm]: 12,8 / 0,0
Line Attenuation (Up/Down) [dB]: 18,9 / 33,5
SN Margin (Up/Down) [dB]: 0,4 / 2,7
Loss of Framing (Local/Remote): 132 / 0
Loss of Signal (Local/Remote): 15 / 0
Loss of Link (Remote): -
Error Seconds (Local/Remote): 768 / 11
FEC Errors (Up/Down): 5.850 / 72
CRC Errors (Up/Down): 0 / 1
HEC Errors (Up/Down): 0 / 1
My SNR is usually 6db.
Can this be investigated further please?
20-03-2014 10:02 AM
I've escalated your Ticket directly our Faults Team for further investigation. (Ticket: 82863911).
Doing an SNR Reset won't fix anything, it could cause the connection to drop more frequently so it'd be much better if we can identify the root cause which our Faults Team will do for you.
20-03-2014 11:20 AM
26-03-2014 9:10 PM
I also had to use my BT Hub 4 to get back on after the last drop. Not sure if the PP hub is faulty or not. I will try it again if things stabilise on the Hub 4
Could not get connected last night and lost dial tone when router was connected. Managed eventually to get on line ine the morning after doing a factory reset on the PP router. Still noise on line even with router unplugged and connected to test socket.
27-03-2014 11:42 AM
When would you be available for a further engineer to visit? We need to get this noise on the phone line issue sorted out for you.
If you could let me know ASAP I'll get one booked in for you. Unfortunately we've no weekend appointments available in your area at the moment.
27-03-2014 11:57 AM
Stats after latest drop.
Link Information
Uptime: 0 days, 0:04:34
Bandwidth (Up/Down) [kbps/kbps]: 906 / 11,179
Data Transferred (Sent/Received) [MB/MB]: 19.41 / 236.33
Output Power (Up/Down) [dBm]: 12.8 / 0.0
Line Attenuation (Up/Down) [dB]: 18.9 / 33.5
SN Margin (Up/Down) [dB]: 6.7 / 6.0
Loss of Framing (Local/Remote): 61 / 0
Loss of Signal (Local/Remote): 8 / 0
Error Seconds (Local/Remote): 102 / 0
FEC Errors (Up/Down): 0 / 215
CRC Errors (Up/Down): 0 / 0
HEC Errors (Up/Down): 0 / 0
27-03-2014 12:01 PM
Morning: 8am-1pm / Afternoon: 1pm-6pm
27-03-2014 12:10 PM
27-03-2014 12:20 PM
04-04-2014 9:36 AM
Link Information
Uptime: 0 days, 0:04:03
Bandwidth (Up/Down) [kbps/kbps]: 924 / 10,794
Data Transferred (Sent/Received) [MB/GB]: 466.75 / 1.99
Output Power (Up/Down) [dBm]: 12.7 / 0.0
Line Attenuation (Up/Down) [dB]: 18.8 / 34.0
SN Margin (Up/Down) [dB]: 8.9 / 6.0
Loss of Framing (Local/Remote): 544 / 0
Loss of Signal (Local/Remote): 65 / 0
Error Seconds (Local/Remote): 4,907 / 120
FEC Errors (Up/Down): 0 / 4,207
CRC Errors (Up/Down): 0 / 42
HEC Errors (Up/Down): 0 / 2,555
Every thing has been left connected to the test socket on the NTE5
Help!!!!!!!
- « Previous
- 1
- 2
- Next »
