DNS:
- DNS:
DNS:
14-05-2012 4:49 AM
Re: DNS:
14-05-2012 6:48 AM
Re: DNS:
14-05-2012 9:58 AM
Re: DNS:
14-05-2012 11:52 AM
Re: DNS:
14-05-2012 11:53 AM
Quote from: dvorak Yes, but as they supply a few - which one?
Technicolor tg582n.
Re: DNS:
14-05-2012 12:06 PM
You'd need to run a few commands using telnet and the CLI interface. From a command prompt type the following and press enter:
telnet 192.168.1.254
You'll be prompted for the admin username and password. Unless you've changed this, the username will be 'admin' (minus the quotes) and the password will be the serial number on the base of the router (it's case sensitive so any letters need to be typed in upper case).
Once you're logged in run the following commands in order, pressing enter at the end of each. You should replace the x's with the DNS server addresses you're wanting to use. The first is the primary server address, the latter the secondary.
:dns server route add dns=xxx.xxx.xxx.xxx metric=1 intf=Internet
:dns server route add dns=xxx.xxx.xxx.xxx metric=2 intf=Internet
:saveall
quit
That /should/ do the trick.
Re: DNS:
15-05-2012 1:37 AM
Re: DNS:
15-05-2012 2:27 AM
Don't forget to saveall afterwards.
Re: DNS:
15-05-2012 9:48 AM
Quote from: tomxlisa ...but that means doing it on every computer,
DNS server address is usually an option in a router's DHCP server set up.
So you could set the DNS server addresses you want to use in the routers DHCP server options and you don't have to set it on every PC.
A little more detail.
Routers typically make little or no use of DNS themselves. Some routers provide a DNS cache, which should provide a quicker response (in theory) to the PCs configured to use it. However, in my experience cheap routers can be so underpowered that cached responses are slower than forwarding.
I should point out that I have little experience with PN provided routers.
