DNS server settings
- Re: DNS server settings
DNS server settings
15-09-2014 3:59 PM
Can anyone explain why I can't use DHCP to retrieve the DNS settings from PN? I have FTTC with a Netgear WNR1000v3 router. If I set the DNS servers manually all is OK but if I select "Get automatically from ISP" we just see BT holding web pages instead.
Message 1 of 3
(592 Views)
2 REPLIES 2
15-09-2014 4:41 PM
It isn't the first time we've seen this and it only seems to happen on fibre.
I believe it happens when you have a disconnection and try to reconnect whilst the previous session is still active. Its a strange one but like you say changing the DNS manually does the trick.
Message 2 of 3
(361 Views)
15-09-2014 4:52 PM
Thanks. I did have some connection issues earlier on. If I switch my router off, how long before the session times out?
Message 3 of 3
(361 Views)
