DNS problems again ?
- DNS problems again ?
01-09-2009 11:23 AM
Any particular reason why DNS has gone all cranky again as of fairly recently ... or is it just me ? because there's no service.status or other complaints that I can see.
However, 212.159.13.49 doesn't appear to be responding at all to any DNS queries but it does respond to a tracert and so on. I'm just getting a timeout on any DNS query. 212.159.13.50 does still appear to be working largely as it should be but it's unbelievably slow needless to say no doubt due to being grossly overworked and all that. Everything's slowly grinding to an almost complete halt via pte-ag1
I saw a few intermittent occasions over the weekend when something similar seemed to be happening but it's definitely looking a bit permanent now. Maybe someone could wander over and threaten it with a big stick or otherwise give it a good kick or something ?
B T Plusnet, a bit kinda like P T Barnum ...
... but quite often appears to feature more clowns
Message 1 of 9
(1,725 Views)
8 REPLIES 8
Re: DNS problems again ?
01-09-2009 2:31 PM
I can not get any response from 212.159.13.49 either.
Using Debian Linux:
nigel@nigel-main:~$ dig @212.159.13.49 www.plus.net
; <<>> DiG 9.5.1-P3 <<>> @212.159.13.49 www.plus.net
; (1 server found)
;; global options: printcmd
;; connection timed out; no servers could be reached
nigel@nigel-main:~$ traceroute www.plus.net
traceroute to www.plus.net (212.159.9.2), 30 hops max, 40 byte packets
1 * * *
2 lo0-plusnet.pcl-ag02.plus.net (195.166.128.39) 21.661 ms 22.016 ms 22.308 ms
3 gi1-2-904.pcl-gw02.plus.net (84.92.0.141) 22.457 ms 23.291 ms 23.325 ms
4 te2-2.thn-gw2.plus.net (212.159.0.190) 35.451 ms 35.515 ms 35.542 ms
5 vl23.pte-gw2.plus.net (212.159.4.28) 37.164 ms 37.228 ms 37.241 ms
6 92.core.plus.net (212.159.1.92) 43.411 ms 21.897 ms 21.890 ms
7 fhw-lb04.plus.net (212.159.1.146) 29.439 ms 29.339 ms 28.534 ms
8 fhw-lb04.plus.net (212.159.1.146) 28.522 ms 19.302 ms 21.126 ms
nigel@nigel-main:~$ traceroute 212.159.13.49
traceroute to 212.159.13.49 (212.159.13.49), 30 hops max, 40 byte packets
1 * * *
2 lo0-plusnet.pcl-ag02.plus.net (195.166.128.39) 18.198 ms 19.058 ms 19.097 ms
3 gi1-2-904.pcl-gw02.plus.net (84.92.0.141) 19.120 ms 20.833 ms 21.528 ms
4 * * *
5 * * *
6 * * *
7 * * *
8 * * *
9 * * *
10 * * *
11 * * *
12 * * *
13 * * *
14 * * *
15 * * *
16 * * *
17 * * *
18 * * *
19 * * *
20 * * *
21 * * *
22 * * *
23 * * *
24 * * *
25 * * *
26 * * *
27 * * *
28 * * *
29 * * *
30 * * *
and for comparison
nigel@nigel-main:~$ dig @212.159.13.50 www.plus.net
; <<>> DiG 9.5.1-P3 <<>> @212.159.13.50 www.plus.net
; (1 server found)
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 56218
;; flags: qr rd ra; QUERY: 1, ANSWER: 3, AUTHORITY: 2, ADDITIONAL: 2
;; QUESTION SECTION:
;www.plus.net. IN A
;; ANSWER SECTION:
www.plus.net. 72327 IN CNAME portal.plus.net.
portal.plus.net. 410 IN A 212.159.8.2
portal.plus.net. 410 IN A 212.159.9.2
;; AUTHORITY SECTION:
plus.net. 72323 IN NS ns1.force9.net.
plus.net. 72323 IN NS ns2.force9.net.
;; ADDITIONAL SECTION:
ns1.force9.net. 72323 IN A 195.166.128.16
ns2.force9.net. 72323 IN A 195.166.128.17
;; Query time: 28 msec
;; SERVER: 212.159.13.50#53(212.159.13.50)
;; WHEN: Tue Sep 1 14:30:17 2009
;; MSG SIZE rcvd: 158
Nigel
Using Debian Linux:
; (1 server found)
1 * * *
1 * * *
4 * * *
5 * * *
6 * * *
7 * * *
8 * * *
9 * * *
10 * * *
11 * * *
12 * * *
13 * * *
14 * * *
15 * * *
16 * * *
17 * * *
18 * * *
19 * * *
20 * * *
21 * * *
22 * * *
23 * * *
24 * * *
25 * * *
26 * * *
27 * * *
28 * * *
29 * * *
30 * * *
and for comparison
; (1 server found)
;; Got answer:
;www.plus.net. IN A
;; ANSWER SECTION:
Nigel
Message 2 of 9
(830 Views)
01-09-2009 3:25 PM
Its working here:
; <<>> DiG 9.4.2-P2 <<>> @212.159.13.49 www.plus.net
; (1 server found)
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 41241
;www.plus.net. IN A
;; ANSWER SECTION:
www.plus.net. 69617 IN CNAME portal.plus.net.
portal.plus.net. 381 IN A 212.159.9.2
portal.plus.net. 381 IN A 212.159.8.2
plus.net. 69595 IN NS ns1.force9.net.
plus.net. 69595 IN NS ns2.force9.net.
ns1.force9.net. 69637 IN A 195.166.128.16
ns2.force9.net. 69943 IN A 195.166.128.17
;; Query time: 46 msec
;; SERVER: 212.159.13.49#53(212.159.13.49)
;; WHEN: Tue Sep 1 15:23:26 2009
But I've noticed a few stalls over things
; (1 server found)
;; Got answer:
;www.plus.net. IN A
;; ANSWER SECTION:
Message 3 of 9
(830 Views)
01-09-2009 4:07 PM
It's started working here again.
Could be an intermittent problem or linked to some maintenance work?
; (1 server found)
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 23713
;www.plus.net. IN A
;; ANSWER SECTION:
www.plus.net. 67156 IN CNAME portal.plus.net.
portal.plus.net. 629 IN A 212.159.9.2
portal.plus.net. 629 IN A 212.159.8.2
plus.net. 67134 IN NS ns2.force9.net.
plus.net. 67134 IN NS ns1.force9.net.
ns1.force9.net. 67176 IN A 195.166.128.16
ns2.force9.net. 67482 IN A 195.166.128.17
;; Query time: 60 msec
;; WHEN: Tue Sep 1 16:04:27 2009
NIgel
; (1 server found)
;; Got answer:
;www.plus.net. IN A
;; ANSWER SECTION:
NIgel
Message 4 of 9
(830 Views)
01-09-2009 8:33 PM
Yeah, and it's working here again as well now Pity that no one was apparently able to give any official response over the last 9+ hours as to if/why it was AWOL earlier today (as indeed it also appears to have been on various other occasions particularly over recent days) because I can't see any service.status which appears that relevant to DNS stylee issues like this. Several second delays on each/every look-up when using the secondary server doesn't exactly give the best of browsing experience to say the least ! But then again it did lead to me pulling the plug and wandering off to do something sort of useful (for a change) rather than struggling along, getting annoyed or wasting my time/effort trying to work out was was (or wasn't) going on so not all bad news
I also find it more than a bit strange that the DNS monitoring help/status page showing response times doesn't even hint at there being any problems either ! And neither has it done so in the past when there clearly has been some issue or other with at least some of the servers or when trying to access them via some gateways.
Is the DNS monitoring page currently showing an incomplete set of data or is it perhaps more a case of any monitoring that is being done is not really in any way representative of what a customer is actually experiencing in the Real World TM ? It seems very strange to me that there obviously was something more than a bit odd going on once again today but firstly, no one else seems particularly bothered about it and secondly, there's no problem at all according to the PN system monitoring and service.status pages. I can see a recent service.status relating to authoritative DNS servers but it's not really relevant to this by all accounts.
Message 5 of 9
(830 Views)
01-09-2009 8:51 PM
What are these numbers
Quote Service Status RSS Feeds
Planned authoritative DNS server maintenance - Wednesday 2nd September 2.00am-4.00am
Internet Connectivity
Posted on: Tuesday 1 September 2009, 16:58
When's this work happening?
Tomorrow morning.
What does it affect?
One of our authoritative DNS servers (NS1) -
http://en.wikipedia.org/wiki/Authoritative_name_server#Authoritative_name_server
How long will it take?
About an hour.
What does the work involve?
We will be performing a software upgrade to resolve a recently identified problem with the server.
Is it likely to cause problems?
It shouldn't do. The server may become unresponsive for an hour during the maintenance window however the secondary server should be able to handle any requests. Whilst we don't recommend doing so, some customers /may/ be using one or more of the following server addresses for DNS resolution. These customers may experience problems browsing the Internet during the maintenance window and are advised to switch to the recommended server addresses which can be found on our website - http://www.plus.net/support/customer_service/using/settings.shtml?supportc=rhm_connectiondetails
195.166.128.16
212.159.11.129
212.159.11.150
212.159.11.151
212.159.11.155
Is there anything else I need to know?
No.
Kind Regards,
Customer Support
Message 6 of 9
(830 Views)
01-09-2009 9:53 PM
F9, PN and BT authoritative name servers various - ns1.force9.net and so on. Not the servers [generally] used directly by customers for random queries.
The recommended DNS servers are 212.159.13.49/50 according to the help pages ... although my connection generally seems to obtain 212.159.6.9/10 when connecting and always has done. Dunno why but I seem to remember reading somewhere that all roads lead to the same bunch of actual servers via load-balancers anyway so it quite possibly doesn't matter which IP is actually specified. I always override the obtained IPs.
There's a whole bunch of others (such as 212.159.13.150) that are ns2.[whatever] as well of course which I would guess will be getting the same treatment at some later point in time if they haven't already had it.
Message 7 of 9
(830 Views)
01-09-2009 9:56 PM
Thanks Mike.
i suppose the reason I don't usually see a problem is that I have hard coded 212.159.13.50 as a primary and 208.67.220.220 as secondary in my router
Message 8 of 9
(830 Views)
01-09-2009 10:15 PM
I experienced a brief problem at around 8 am last Sunday. I immediately thought of Oldjim's ploy tp work around these Plusnet problems but I had not made a note of his alternative (non-Plusnet) DNS server and I could not access the internet to find it!.
What's the point of Plusnet having two DNS servers if one cannot cover for the other being out of action????
Message 9 of 9
(830 Views)
