DNS issues
- DNS issues
DNS issues
18-03-2008 11:30 AM
Hi
Normal web browsing is OK. The issue I have is my VPN client (contivity) no longer resolves correctly with the config I had.
Its first choice was plusnet DNS servers second a company DNS server. This meant that all non company traffic went direct to plusnet and company traffic down the VPN tunnel.
As of this morning this setup no longer works and I had to modify my VPN client setup to only use the company DNS server.
What else changed on the DNS setup last night apart from adding a load balancer?
Nick
Nick
Message 1 of 5
(1,196 Views)
4 REPLIES 4
Re: DNS issues
18-03-2008 11:38 AM
Which Plusnet DNS servers were you using?
Message 2 of 5
(439 Views)
Re: DNS issues
18-03-2008 11:42 AM
That I cant answer as I never check and they are assigned automatically to my router via plusnet
Message 3 of 5
(439 Views)
Re: DNS issues
18-03-2008 11:46 AM
Can you try specifying them manually to see if it resolved your problem?
Message 4 of 5
(439 Views)
Re: DNS issues
18-03-2008 11:59 AM
I will go dig out the plusnet DNS server IP addresses and add to my router and test
Regards
Nick
Regards
Nick
Message 5 of 5
(439 Views)
