DLM Trial -- Whats happening??
- DLM Trial -- Whats happening??
Re: DLM Trial -- Whats happening??
04-01-2011 1:22 PM
A line will seem stable while it's being banded because it's not syncing high enough for the faults to occur. Chances are if the banding is lifted then the line would become unstable again.
Jojo
04-01-2011 1:24 PM
[quote=Force9Original]Would a line that syncs below fault threshold fall into the criteria
That would be raised as a fault immediately.
Jojo
04-01-2011 1:42 PM
thanks f9o
04-01-2011 2:05 PM
I've passed that over to one of the guys who deals with that. He's going to take a look at your account and see if it's viable.
Jojo
04-01-2011 3:05 PM
I'm sure lots of people would benefit from being taken out of the DLM rollercoaster.
Graham
04-01-2011 3:10 PM
Quote from: Joanne A line will seem stable while it's being banded because it's not syncing high enough for the faults to occur. Chances are if the banding is lifted then the line would become unstable again.
Interleaving is also used to make a line stable. So if I had a choice to move to the next band or to have interleaving switched off I would go for the former. It seem that the DLM favour removing Interleaving not increasing the speed.
04-01-2011 4:20 PM
Line added to 21cn DLM override trial.
Profile hard fixed to
WBC 160K - 24M No delay (INP 0) 6dB Downstream, UC
Thanks Jojo & Alex !
22-07-2011 10:18 AM
22-07-2011 11:33 AM
We're still able to request these profiles in certain circumstances. I'm not sure whether they're still classing it as a trial. Even if they were to end it, you wouldn't lose what you have now.
Jojo
30-07-2011 7:41 PM
Under what circumstances are needed to opt out of the dlm control ?
Would i be considered for this ?
Paul.
01-08-2011 2:28 PM
There's many different things to take into account, not necessarily a criteria, just more about whether we think it would help. DLM is still in place, it just means the line can't be banded,so you will always sync at the highest possible rate.
Jojo
01-08-2011 3:22 PM
I have always limited my testing here to try and avoid this problem,but as i have sync'd 2500-2600kb,i would like to be able to test more often as i am sure i would eventually be able to get my sync above 2800kb and get me on to the next profile of 2500kb.
For instance i have various firmwares to try as well as some filter designs i have made,being able to test these without fear of problems with banding would be great.
Paul.
02-08-2011 10:53 AM
Quote from: maximod Does this mean if i have the banding removed i could do more testing here of different modems (many connect/disconnects),without my profile suffering ?
Yes, there is that. Just remember, though, that a low sync event could cause the profile to drop, in which case it would still take the normal time at a higher sync rate to raise up again.
Jojo
02-08-2011 1:19 PM
So if i have got this right, if my banding was removed, my connection would always connect for a target snr of 6db regardless of how many connects/disconnects ?
But my profile could be reduced if i were to sync lower than the required profile (as it would do normally) ?
Thanks,
Paul.
02-08-2011 2:33 PM
Yes, the fixed profile means that every reconnection would start at the target SNR but it is still subject to profile changes in the normal way.
Jojo
