DLAN Disconnecting DSL
- DLAN Disconnecting DSL
09-05-2009 11:33 AM
There's about two meters in between the router and dlan device so as to avoid interference if that were to be the issue...
Re: DLAN Disconnecting DSL
09-05-2009 4:51 PM
Have you turned off the wireless on the 585 if you are no longer using it, or if it's still being used on another channel away from the DLAN channels?
09-05-2009 11:29 PM
10-05-2009 12:21 PM
In view of your problems better have the error stats as well as DS and US line figures.
10-05-2009 6:41 PM
DSL Type: G.992.1 annex A
Bandwidth (Up/Down) [kbps/kbps]: 448 / 7,584
Data Transferred (Sent/Received) [kB/kB]: 0.00 / 23.00
Output Power (Up/Down) [dBm]: 11.5 / 19.5
Line Attenuation (Up/Down) [dB]: 20.0 / 31.0
SN Margin (Up/Down) [dB]: 24.0 / 6.0
Vendor ID (Local/Remote): TMMB / ALCB
Loss of Link (Remote): 0
FEC Errors (Up/Down): 0 / 18,488
CRC Errors (Up/Down): 0 / 35
HEC Errors (Up/Down): 0 / 30
Better to have as much info as possible. Many thanks for your input.
10-05-2009 10:48 PM
10-05-2009 11:14 PM
Uptime: 0 days, 2:44:15
Bandwidth (Up/Down) [kbps/kbps]: 448 / 7,616
SN Margin (Up/Down) [dB]: 23.0 / 6.0
FEC Errors (Up/Down): 0 / 2,182
HEC Errors (Up/Down): 0 / 1
11-05-2009 12:27 AM
20-05-2009 11:08 AM
Uptime: 0 days, 0:04:39
Data Transferred (Sent/Received) [kB/kB]: 0.00 / 28.00
SN Margin (Up/Down) [dB]: 24.0 / 6.5
FEC Errors (Up/Down): 0 / 38
CRC Errors (Up/Down): 0 / 0
HEC Errors (Up/Down): 0 / 0
20-05-2009 11:40 AM
20-05-2009 10:34 PM
Your line stats look good, so we better check the basics first.
Listen to your phone line, can you hear any crackling or other intermittent noises? Do you recall hearing any in the past?
Do you have extension sockets and are you plugged into one or are you plugged into the master? If you have fixed extensions and wiring, do you know if the bell wire is still connected?
If you have extension wiring, can you plug into the test socket which is behind the removeable lower front part of the master linebox. Be careful not to pull out any extension wiring connected to the removeable faceplate. Check also that all extensions are dead with the faceplate removed.
Also look to see if any wires are connected to terminals 3&4 on the rear of the removeable faceplate.
You'll need to stay connected to the test socket like this for a while to see if this stabilises the situation.
If there is no change, try another filter. If still no change try another modem/router.
