DIR-615 and DD-WRT
- Re: DIR-615 and DD-WRT
DIR-615 and DD-WRT
20-12-2013 6:22 PM
BT HUB 5 ---> SamKnows (internet is passed and reach websites on smart tv and PS3) ---> D-Link DIR 615 (internet connected and CAN'T reach websites) ----> WNR1000 (connected to internet and CAN'T reach websites)
There is obviously a problem on the DD-WRT router where it's stopping the internet passthrough but still enabling internet but non actually. If you load google it takes forever then eventually times out.
Anyone help?
20-12-2013 6:34 PM
Can you access the DD-WRT web GUI? Does it show that it has got a WAN address? What do you mean that you could 'connect to the net but not websites' when you connected via ethernet? Have you rebooted the 615? Can you ping a website from the 615 (web GUI or telnet/ssh)? What IP range is on the DD-WRT LAN on what IP range does the HH5 dish out?
Quote from: NorthEasterner There is obviously a problem on the DD-WRT router where it's stopping the internet passthrough but still enabling internet but non actually. If you load google it takes forever then eventually times out.
Haven't got a clue what this means I'm afraid...
20-12-2013 6:38 PM
How do I telnet to the DD-WRT and find WAN address and IP range?
Sorry
20-12-2013 6:40 PM
What are you using the 615 to do for you in your setup?
20-12-2013 6:47 PM
Subnet Mask - 255.255.255.0
Gateway - 192.168.1.254
DHCP is off
The operating mode is ROUTER
Dynamic routing interface - WAN
Static Routing interface - LAN & WLAN
Port setup in networking are all set to default
EoIP all disabled
After new post you posted
I am using it for guest hotspot system so it has a landing page. I also get donations for running it by neighbours.
DHCP Server is disabled as the hub 5 does the DHCP
20-12-2013 6:58 PM
You're going to have to explain your setup in a lot more detail I'm afraid - My crystal ball is turned off for Christmas
20-12-2013 7:00 PM
If I factory reset DIR 615 DDWRT, can you guide me through setting it up as an access point for LAN whilst its connected to my HH5?
20-12-2013 7:09 PM
My question about if it has ever worked is important though? If it has worked, what have you changed?
With the 615 plugged up as it is, you are using it as a router so the HH DHCP server will not be visible to clients on the 615 LAN...
20-12-2013 7:14 PM
20-12-2013 7:20 PM
20-12-2013 7:52 PM
Any way to get it back? When I try to access 192.168.1.1 I am presented a login box so I entered the credentials which I used when setting up but it doesn't recognize it and is invalid. When I click cancel I am presented with a webpage in red saying
"401 Unauthorized. Authorization required. please note that the default username is "root" in all newer releases"
Need to get back in so I can set up my hotspot (which I know how to do)
20-12-2013 9:25 PM
User: root
Password: admin
20-12-2013 9:40 PM
Login details for 192.168.1.1:80
20-12-2013 10:06 PM
The D-link's default login details are user "admin", password is blank.
20-12-2013 10:13 PM
Running out of options here
