DGteam dg834g v4 firmware xbox problem.
- DGteam dg834g v4 firmware xbox problem.
30-01-2009 3:55 PM
tried the DGteam firmware last night all looked gd was happy with the extra options but on trying to connect to XBL i was getting the MTU faliure.
checked the router and the upgrade had kept my mtu as normal at 1500. i clicked apply to see if that would kick the mtu setting into life but the xbox still moaned the mtu was below the 1340ish mark.
as i wanted to get on with my gaming i just flashed the router back to the netgear offical firmware and didnt do any checks on the pc to find what was going on.
Has any one else had this problem with the DGteam DG834V4_V5.01.12_DGTeam_0849_023o.img firmware?
should i have used this firmware DG834V4_V5.01.12_DGTeam_0849_023b.img the diffrence being the b and not o which i belive is diffrence in drivers.
Message 1 of 3
(1,985 Views)
2 REPLIES 2
Re: DGteam dg834g v4 firmware xbox problem.
30-01-2009 3:56 PM
What you need is a PS3, works great the the DGTeam firmware
Message 2 of 3
(352 Views)
30-01-2009 6:12 PM
@adiewoo. why dont you recomend all those people on the gaming forum to upgrade to DGteam firmware when there PS3's will not talk to the internet then.
if you stand for modrater adiewoo i will vote for you if one of your polices is to make a new section in the gamers forum just for ps3 problems looks ever so messy with all thoses theards on ps3 at the mo
Message 3 of 3
(352 Views)
