DG834 - netgear router
- Re: DG834 - netgear router
06-12-2012 7:36 AM
Works well apart from very rarely resets its self to ‘factory settings’ for no apparent reason. Just at a random point in time, it is surge protected, has the latest firmware, is about 5 years old.
Any thoughts would be appreciated.
Message 1 of 7
(1,443 Views)
6 REPLIES 6
06-12-2012 8:30 AM
Unless there is something you need that it does not do, stick with it.
Message 2 of 7
(554 Views)
06-12-2012 8:48 AM
@RR:- thanks.
Message 3 of 7
(554 Views)
06-12-2012 10:28 PM
I'd echo RR's view: it's one of the best at holding on to a connection at very low SNR.
Message 4 of 7
(554 Views)
19-12-2012 8:40 AM
I 100% agree.
Over the years I had Sitecom, Dlink, Linksys and even a Cisco 837 at one point running on an ADSL line which then became ADSL2+ Annex M.
By far the highest sync rate and most stable service I could get on the 5 mile long telephone line was with the Netgear DG834.
I wish I could still use it but I have FTTC now.
Message 5 of 7
(554 Views)
19-12-2012 11:13 AM
@Sean Branagh
Keep your old DG834. Give it an IP on your subnet, set the DHCP to a different range from your existing router and enable the wireless. Presto! Handy extra Wireless Access Point and 4-port switch! Just remove all your details from the onboard ADSL modem, untick "Auto Reconnect", and ignore it.
--Dave
--Dave
A tortoise? What's that?
You know what a turtle is? Same thing.
Message 6 of 7
(554 Views)
19-12-2012 12:01 PM
It is a DG834 not a DG834G so it has no access point. Being that the switch is only 100Mbps and unmanaged, I would have no use for it either.
It is just in a box along with other spare parts I will probably never need.
Message 7 of 7
(554 Views)
