Current sped drop - result of flooding?
- Current sped drop - result of flooding?
26-11-2012 7:15 PM
I had a REIN issue earlier in the year, but that got sorted and I've just checked with an AM radio and don't appear to have any (noticeable) interference at the moment.
Thanks.
Re: Current sped drop - result of flooding?
26-11-2012 7:34 PM
26-11-2012 7:52 PM
26-11-2012 9:19 PM
26-11-2012 9:36 PM
27-11-2012 11:39 AM
Your line has been banded and interleaving has been turned on as your line is currently experiencing a high amount of errors. This is why you are receiving slower speeds.
I've ran a test on your line and there is no fault detected, I'd suggest leaving your connection on and see how it is over the next 24 hours and see if there's any change.
27-11-2012 6:08 PM
I'm not sure what to do about it as the phone line is fine yet constant lower sync speed compared with a week or so ago. I'll leave routerstats running. Nothing has changed my end, only one phone connected to the master socket and via a filter etc. I suppose there's nothing more that I can do at this stage except wait and if there's no improvement register a fault?
Does anyone know why it's connecting as ADSL2 and not ADSL2+?
Link Information
Uptime: 0 days, 6:57:13
DSL Type: ITU-T G.992.3
Bandwidth (Up/Down) [kbps/kbps]: 1.076 / 1.760
Data Transferred (Sent/Received) [GB/GB]: 1,99 / 1,99
Output Power (Up/Down) [dBm]: 12,8 / 0,0
Line Attenuation (Up/Down) [dB]: 26,4 / 47,0
SN Margin (Up/Down) [dB]: 5,1 / 5,4
Loss of Framing (Local/Remote): 17 / 0
Loss of Signal (Local/Remote): 2 / 0
Loss of Link (Remote): -
Error Seconds (Local/Remote): 9.027 / 0
FEC Errors (Up/Down): 0 / 3.445.332 <-- High errors
CRC Errors (Up/Down): 110 / 3.341
HEC Errors (Up/Down): 45 / 10.332
Steve
27-11-2012 6:47 PM
28-11-2012 9:08 AM
Can some of you nice folk at PN issue a SNR reset and raise my IP profile back again please?
28-11-2012 11:02 AM
I'd be happy to but there's been a couple of disconnections on your line over the past couple of days:
<img src="http://ccgi.psmith12.plus.com/visradius/generated/image13541004226706.png"/>
That may well cause your line to train at a lower profile than it might if things were stable, I think it'd be best to wait a couple of days to confirm it is stable before we do the reset - your call though.
28-11-2012 11:11 AM
I'm happy for you to do a SNR reset as it has to be the fact that the router was sat on the power block!
Thanks.
28-11-2012 11:26 AM
28-11-2012 11:28 AM
28-11-2012 11:39 AM
28-11-2012 11:43 AM
