Current line speed change
- Re: Current line speed change
29-03-2014 1:49 PM
IP Profile for your line is - 43.13 Mbps
Current line speed: 24 Mb
Could that be fixed please?
Message 1 of 6
(948 Views)
5 REPLIES 5
29-03-2014 1:58 PM
At the weekends, there may not be any staff on the forum. Best off if you call support.
Message 2 of 6
(516 Views)
30-03-2014 12:02 AM
I see someone (or something) updated it to Current line speed: 37.4 Mb
Download speed achieved during the test was - 22.65 Mbps
For your connection, the acceptable range of speeds is 30.19 Mbps-43.13 Mbps .
Additional Information:
I guess that wasn't it then...
Message 3 of 6
(516 Views)
31-03-2014 11:57 AM
Your speed profle was automatically updated. I've checked your sync and it's showing it at 38.6Mbp/s which gives you the correct speed profile.
What's your IP profile currently at if you run another speed test?
Message 4 of 6
(516 Views)
31-03-2014 5:16 PM
Getting ~34mb now!
BTW wasn't working when I tried though
Message 5 of 6
(516 Views)
01-04-2014 9:21 AM
Have you tried in another browser to see if the speed test will run?
Message 6 of 6
(516 Views)
