Current Line Speed
Robander80
Current Line Speed
Hi, my current line speed on the member centre is showing 0.5mb, as you probably know this is ridiculously slow and causing me issues. Not only this but the connection keeps dropping. This is a business line and i need a reliable connection. I cant seem to find an explanation as to why i am getting this speed, no faults showing on your website.
Thanks,
Rob
6 REPLIES 6
Legend
Fixes: 254
Re: Current Line Speed
If it is a business line, on a business account, I would suggest you ring the relevant telephone number, and post in the business forum.
MatthewWheeler
Fixes: 479
I've updated that for you but your sync speeds are dropping quite alot.
I'd recommend raising a fault here so we can look into this.
 Matthew Wheeler
Robander80
That did fix it for me on Thursday and i have just put in a fault, but says it can take up to 1-3 to fix. My broadband has just fallen back down to 0.6mbs again, can you do what you did on Thursday to get it back up to speed? cant do anything at this speed.
Thanks.
Robander80
BT Wholesale test is coming back with 6mbs. when through plusnet im getting 0.5mbs.
Chris
Legend
Fixes: 169
Can you try a single disconnect/reconnect of the router and see what speeds you're getting then please.
Robander80
Ok im getting 14.5mbs. Is it fixed now? or am i likely to drop to 0.5 again in a couple of days?
