Creating a Wireless Bridge
- Re: Creating a Wireless Bridge
05-08-2014 11:58 AM
Hi there - innocent newbie here!
I have PLusnet broadband and have just moved to a new house which has deadspots which is very annoying!
So I want to connect a Belkin N Wireless router to my Plusnet Technicolor Router as a bridge to extend the range of the wireless signal. Can anyone please explain how I can do this?
I have logged into both routers' admin pages but can't see how to enable bridging!
Message 1 of 5
(980 Views)
4 REPLIES 4
05-08-2014 12:15 PM
The following link shows how to setup the Technicolor for WDS, Haven't a clue about the Belkin.
http://npr.me.uk/wds.html
WDS gives a very poor performance between two Technicolor routers, I would think it will be even worse between two routers of different make.
I strongly suggest you forget this idea and connect the two routers via ethernet cable or a pair of home plugs.
The following shows how to connect two technicolor routers via ethernet (homeplug), it should give you the general idea for your two routers.
http://npr.me.uk/together.html
Message 2 of 5
(740 Views)
05-08-2014 5:10 PM
Many thanks npr. Will try the homeplug option.
Message 3 of 5
(740 Views)
05-08-2014 5:15 PM
Also consider looking at homeplugs which have built it wireless access points - saving you having to add your own !
http://www.devolo.com/uk/Products/dLAN-Wi-Fi-Adapters-Finally-Wi-Fi-in-any-room
Message 4 of 5
(740 Views)
05-08-2014 5:47 PM
Alternatively you could try a range extender. I have 2 and they work well.
http://www.ebay.co.uk/sch/i.html?_trksid=p2050601.m570.l2632.R2.TR10.TRC1.A0.H0.Xwireless+range&_nkw...
Message 5 of 5
(740 Views)
