Could my speed be checked please
- Could my speed be checked please
14-04-2012 4:38 PM
Re: Could my speed be checked please
14-04-2012 5:03 PM
Can you post the information requested in this thread please http://community.plus.net/forum/index.php/topic,96155.0.html
14-04-2012 5:53 PM
Sorry not sure how to do what you ask.
jim:green link fixed mod:end
14-04-2012 5:59 PM
If it doesn't work can you do it yourself using the second link to find out how which is this http://www.kitz.co.uk/adsl/frogstats.php
Which router are you using
14-04-2012 6:04 PM
14-04-2012 6:10 PM
Plusnet told me it would definitely change my speed to make it faster if I changed to Extra.
14-04-2012 6:14 PM
Log in to the router from http://192.168.1.254
Username and password as per the image below
From the left hand menu:
Broadband Connection >
DSL Connection >
Then select "Details" from the top right.
14-04-2012 6:31 PM
Quote Plusnet told me it would definitely change my speed to make it faster if I changed to Extra.
You shouldn't need to change to Extra to get faster speeds, they are available on Value!.
14-04-2012 6:43 PM
DSL Connection
Link Information
Uptime: 1 day, 23:19:03
DSL Type: G.992.1 annex A
Channel mode: Fast
Maximum Bandwidth (Up/Down) [kbps/kbps]: 1,224 / 8,128
Bandwidth (Up/Down) [kbps/kbps]: 448 / 8,128
Data Transferred (Sent/Received) [kB/MB]: 0.00 / 368.59
Output Power (Up/Down) [dBm]: 12.5 / 17.5
Line Attenuation (Up/Down) [dB]: 7.5 / 15.0
SN Margin (Up/Down) [dB]: 29.0 / 9.5
Vendor ID (Local/Remote): TMMB / TSTC
Loss of Link (Remote): 0
FEC Errors (Up/Down): 0 / 0
CRC Errors (Up/Down): 0 / 784
HEC Errors (Up/Down):
14-04-2012 6:46 PM
1. You are not on ADSL2+ hence your sync speed is being limited to 8,128kbps
2. It is possible that either the IP profile or the Plusnet mirror is restricting you a little bit - the other parts of the tests we wanted will identify that
3. Can you put your telephone number in here and see if 21CN is available http://usertools.plus.net/exchanges/
14-04-2012 6:48 PM
Click here for further details
BT have announced a date for WBC on 21CN
You can view recent Service Outages for this exchange here
BT has published DSL Max upgrade information for this exchange
14-04-2012 7:22 PM
Quote VP capacity at this exchange is currently showing as Red.
That means the exchange is congested and therefore your effective speed may well be reduced at peak times.
Quote BT have announced a date for WBC on 21CN
Until 21CN is available you can not be moved to ADSL2+ for faster speeds.
You are already synching at the maximum speed available for a 20CN connection i.e 8128k.
Edit: the good news is that when 21CN becomes available your potential for speed increase is good.
With your downstream attenuation of 15db you should see a good increase in speed, something in the order of >15Mb should be achievable
14-04-2012 7:33 PM
14-04-2012 7:38 PM
14-04-2012 7:42 PM
It says enabled here jelv.
BT Wholesale information
ADSL status:
Enabled as of 12/11/2003
ADSL Max status:
Enabled as of 31/03/2006
SDSL status:
Not available
21CN WBC status:
Enabled
FTTC status:
Not available
