Contention or Throttling?
- Re: Contention or Throttling?
- « Previous
- 1
- 2
- Next »
06-02-2008 2:23 PM
It's actually done at the DSLAM on your exchange.
Off to go and place the order to remove it now.
Message 16 of 21
(258 Views)
11-02-2008 10:28 AM
Just a quick note to say that by turning off the interleaving everything is now fine. My pings are now about 6-10 which is amazing considering they were around 100-150.
Thanks very much,
Steve
Thanks very much,
Steve
Message 17 of 21
(258 Views)
11-02-2008 10:40 AM
Brilliant.
Fantastic result.
Fantastic result.
Message 18 of 21
(258 Views)
11-02-2008 12:04 PM
Quote from: Jameseh It's essentially something that improves stability and causes latency (ping times) to increase, but isn't needed on decent lines.
what is classed as a "decent line"? i am assuming interleaving is on as standard?
here are my current line stats, but im not on plusnet until friday. i am just curious more than anything else.
Quote from: monkeyexpressPF Bandwidth (Up/Down) [kbps/kbps]: 288 / 2,304
Output Power (Up/Down) [dBm]: 10.5 / 19.0
Line Attenuation (Up/Down) [dB]: 19.5 / 36.0
SN Margin (Up/Down) [dB]: 30.0 / 19.0
Message 19 of 21
(258 Views)
11-02-2008 12:34 PM
I would have thought yours was a decent line but you will only really be able to tell when you are out on MaxDSL - note it would be worth asking PlusNet if that is happening automatically as you seem to be on a fixed speed connection at present
Message 20 of 21
(258 Views)
11-02-2008 12:38 PM
The order has been placed to automatically place you onto the IPStream Max upto 8Mbps service.
So we'll see how it performs once your connection with us goes live
Message 21 of 21
(258 Views)
- « Previous
- 1
- 2
- Next »
