Contact phone numbers
vlbvlb
I have a Netgear 834 router and since Friday I have been unable to connect to the internet. I want to speak to technical support, but none of the phone numbers listed are working (number not recognised). Can anyone help? Please.
regards-Vincent
12 REPLIES 12
reserved
Re: Contact phone numbers
All I have got are:  0845 140 0200  or  0114 296 5188
vlbvlb
I tried the first number last night and this morning with landline and mobile, no good, but just tried it and got through Huh Thanks for the reply...Vince
Strat
Fixes: 565
...or 0114 296 5198 as in my sig but glad you finally got through Smiley
jojopillo
HI Vincent,
did you manage to get through?
Jojo Smiley
vlbvlb
Hello Jojo,
Yes, I did get through to Plusnet, but will leave technical help until it's a bit quieter, thanks.
i've just tried another router, but still cannot connect to the net. I've been tethering since Friday, but it will not allow me to send any emails.
It seems I'm not the only one with a Netgear router who is having problems, any suggestions would be welcome.
Vince
jojopillo
Hi Vince,
Need a bit more info to help. Tell me what lights are on or off on the router.
Jojo Smiley
vlbvlb
All relevant lights are on (green) apart from the internet light which is red.
jojopillo
Hi vlbvlb,
Firstly check that the router has your correct username and password in
username = username@plusdsl.net
Password = account password.
The reason I ask this is that sometimes routers can factory reset, losing your settings.
If they are set correctly try rebooting your router if you have not dine that already.
If you still can't connect then try
Username = bt_test@startup_domain
Password = test
Then
Username = bt_test_user@plusdsl.net
Password = test
Please make sure you give these test log ins a couple of minutes to try to authenticate before deciding that they don't work.
Let me know how you get on.
Jojo Smiley
vlbvlb
Hi Jojo,
I have tried the two tests but both seem to fail. Checked all that you've asked me to do and others more than once, but still no connection.
i'll leave it until the morning,nite,nite. Smiley
Regards-Vince
jojopillo
HI Vince,
I have raised a fault for you. Let me know if there is anything else you think may be relevant.
Jojo Smiley
vlbvlb
Morning Jojo,
One thing i can't understand, is why I can download emails(via tethering), but not send them,feels as though something is corrupted your end.
Got another dg834 that I can try tonight, I may as well give it a go just in case.
Vincent
jojopillo
Hi vlbvlb,
If you are using another network for email you'll need to enable SMTP authentication for your outgoing server in your client. Alternatively you can use your mobile network's outgoing mail server instead.
Jojo Smiley
