Constant drop outs
- Constant drop outs
- « Previous
- 1
- 2
- Next »
Re: Constant drop outs
06-03-2015 10:52 AM
If the problem is in the Eside though, fibre will fix it, and theres a good chance it will be sorted if the problem is in the customer property. The only problem would be the d-side which I hope an engineer would discover on the install of the fibre.
Message 16 of 20
(460 Views)
06-03-2015 11:05 AM
One would hope he would discover it if it was 'D' side Tony, but there would still be the "pain" of the fix
Message 17 of 20
(460 Views)
10-03-2015 4:06 PM
Fibre was installed today and the engineer reported all working as normal - so any issues seemed to be cleared up by the new install
Many thanks for all your help - now just need some ideas on how to to use utilise the extra speed!
Message 18 of 20
(460 Views)
10-03-2015 7:54 PM
Message 19 of 20
(460 Views)
10-03-2015 10:33 PM
If everyone in the family starts streaming at the same time, that'll use up your bandwidth
Message 20 of 20
(460 Views)
- « Previous
- 1
- 2
- Next »
