Constant Internet Disconnections
- Re: Constant Internet Disconnections
20-11-2013 6:37 PM
Happens in the evening not the daytime , Internet hangs then restarts after a few min.
Any help appreciated
Message 1 of 6
(908 Views)
5 REPLIES 5
20-11-2013 8:23 PM
My connections drops once a week always in the evening and it quickly connects I suppose you can call it a automatic bootup for the router I suppse you can call it Ground Hog week,it is not a problem but just odd.
Message 2 of 6
(512 Views)
20-11-2013 8:46 PM
@sully48 - how often does it drop? Daily/weekly?
Message 3 of 6
(512 Views)
21-11-2013 12:03 PM
Your line is dropping quite severely :
<img src="http://community.plus.net/visualradius/generated/image1385035268118.png"/>
Have you changed anything recently, is there any noise/interference on your phone line?
Message 4 of 6
(512 Views)
21-11-2013 2:19 PM
Thanks for the reply , as far as im aware nothing has been changed , my PC is connected via Ethernet and others wireless nothing new has been added to the setup.
I might dig out some old filters and try these if that could possibly cause the issue?
Message 5 of 6
(512 Views)
21-11-2013 2:23 PM
It would be worth a try and that could potentially be the cause. If you could try alternative microfilters, that'd be great.
Message 6 of 6
(512 Views)
