Constant DNS issues
- Constant DNS issues
Re: Constant DNS issues
02-11-2016 11:12 PM
05-11-2016 10:43 AM
Well it seems, using the TOR browser works a treat, shame nothing else works, steam, origin, consoles etc
05-11-2016 10:44 AM
I can even post freely on here without taking 10 minutes and 15 attempts.
05-11-2016 11:07 AM
Very odd problem that, so i guess DHCP is giving all your devices an ip then, but your not not able to resolve anything at all?
Have you not got an old Modem knocking about to try ?
05-11-2016 12:52 PM
yeah DHCP working fine it seems. It's just anything that needs a URL doesn't get resolved right away, might take 2-3 times, I'll get a timeout, cannot resolve URL and DNS config error then, maybe, just maybe I can view a page. obvisouly things like origin and steam which connect to a url say login.origin.com etc don't work as they time out right away.
Been going on for a week now, I'm the infrastructure manager/sysadmin for an IT building and if I'd left any of my tennants with unusable internet I'd be out on my [-Censored-]. I have to be able to work from home sometimes and this is just unacceptable.
05-11-2016 12:53 PM
After being on the phone for 90 minutes one of the guys at plus.net sent me a new router, has made no difference sadly
05-11-2016 1:12 PM
Seems the router is using itself as a primary dns server and failing, results from nslookup
> www.google.com
Server: dsldevice.lan
Address: 192.168.1.254
Non-authoritative answer:
DNS request timed out.
timeout was 2 seconds.
Address: 172.217.23.36
05-11-2016 1:53 PM
I would agree something isn't quite right there, further investigation required locally i'd say.
Raising a ticket and keep plugging it till one of the guys turns up after the weekend!
05-11-2016 2:33 PM
Try using 8.8.8.8 and 8.8.4.4 as the primary and secondary nameserver IP address.
07-11-2016 8:46 AM
Turns out after spending a big chuck of the weekend with one of the plus.net guys that it's their end all along!!
07-11-2016 3:05 PM
Nothing needs doing locally, Locally everything is spot on (as I'd expect it to be saying I do it as a living). After some investigation with the PN guys, turns out everyone was moved to new network over the past few months, and while I was technically moved as I'd not had a disconnect since then I wasn't actually ON the new network, when I rebooted my router on the 28th, I was then assigned the new network and it turns out that the new network is the issue. While the issue is still present I'm now on the old network till they fix it (turns out I'm not the only one).
07-11-2016 5:32 PM
Glad you got it fixed. I'm pretty sure that using Google dns ip addresses as I suggested would have worked given that the tor browser worked for you, but it would have just been a workaround for whatever the actual problem with dns is on the new network. I had to use this trick many times in the past as a BT customer..
07-11-2016 8:57 PM - edited 07-11-2016 9:02 PM
I thought either Local exchange problem or account issue in all honesty.
Glad your on the way to it being fixed, I'm liking the New network by the way!
08-11-2016 9:53 AM
Using differing DNS servers in 3rd party software makes no difference if the connection itself doesn't know where to look. Turns out my problem isn't fixed as when I got home yesterday the problem was back, after another hour on the phone to PN turns out the fix we had in place we weren't allowed to do (some manager says we can't do that anymore) and my account will have had lots of extra charges on for the work I did with them, so I am now without connection, I know what the problem is, I know what the fix is, but being told they won't do it and will be thursday at the earliest before anyone will even look at it.
08-11-2016 10:51 AM
You'd be telling the connection to look at Googles server on ip address 8.8.8.8 for dns resolution.. Give it a try, it wont take long and I think it might well get you working again given that the tor browser worked.
