Considering upgrade to Broadband Pro
- Considering upgrade to Broadband Pro
25-01-2011 11:11 PM
Hi, the product I am currently using is "Free-Online Broadband Pay As You Go with included 6GB bandwidth" for £14.99 a month. Now as I keep breaching my bandwidth limit I am considering migrating to Broadband Pro. My question is does my current package give me anything at all that the Pro package does not include. If they are the same (or at least as good) as each other in all respects then the upgrade looks pretty tempting.
Thanks,
Rob
Thanks,
Rob
Message 1 of 3
(642 Views)
2 REPLIES 2
Re: Considering upgrade to Broadband Pro
25-01-2011 11:50 PM
http://usergroup.plus.net/prodcomp1.php allows you to see the differences.
Speeds on pro will be faster (although gaming will be the same for known games) but the peak period is much more on pro ( 8am -> midnight) compared to your 4pm -> midnight.
[edit to add]
Hmm.. just checked the above link ans assuming you are the same as Legacy: PAYG, the speeds and peak periods are the same so your choice
[edit to add]
Message 2 of 3
(336 Views)
26-01-2011 12:08 AM
The current products don't include webspace and a static IP is extra. However those upgrading from older products can retain existing add-ons on request.
David
Message 3 of 3
(336 Views)
