Considering switch from PAYG to BBYW2
- Considering switch from PAYG to BBYW2
21-03-2008 2:47 PM
So I'm thinking about moving to BBYW2. Now, I've read everything I can find about how traffic is 'sorted' on that product, and how it compares with PAYG. But because there is a lot of information that one has to take in, I would just like to confirm the following:
Most of my internet usage comes from web browsing, downloading small files over HTTP, using MSN, IRC and e-mail. As I understand it, I should see no difference whatsoever when using these things on BBYW2. Correct? I do however download stuff from iTunes every so often, and of course there are always software updates that need installing. These, I suspect, are hosted by Akami so I should expect them to be rate limited to 1Mbps between 4pm and 12am, correct?
Further to that, I do know that PN's rate limits aren't static 100% of the time - i.e. when there's spare capacity some of the limits will be reduced. In light of this, how 'common' is the 1Mbps rate limit discussed above? In other words, am I likely to see it pretty much all the time aside from Christmas Day, or will it probably only be noticeable on certain days of the week?
Any advice appreciated. Thanks!
Re: Considering switch from PAYG to BBYW2
21-03-2008 5:15 PM
My sych speed is 8128/448, line speed 7,150kbps and +Net connection speed 7,000kbps. During quiet times....say 7:00am, my actual download speed is consistently approx 6,300kbps.....at other times, it rarely drops below 5,000kbps. Interleaving is "on."
I use Gradwell 'phone, MSN chat, e-mail, 'net browsing and prior to 8:00am iPlayer.
All these services perform very well indeed. iPlayer downloads very briskly.....2x1-hour progs in 1/2-hour, or less, easily!
In my router, WAN direction: VoIP is given highest priority, e-mail medium priority and www low priority. All rules are allocated 100kbps. Router, LAN direction: same priorities, all rules allocated 20,000 kbps.
I very rarely experience line drops.
Regards.....Noel
21-03-2008 9:50 PM
21-03-2008 9:57 PM
You have understood the difference and how the traffic management works very well.
With P2P/Usenet etc, the limits are variable depending on central capacity.
So, from wht you have said you should not notice any diference most of the time.
22-03-2008 9:13 AM
24-03-2008 6:22 PM
I do however tend to schedule most downloads of over 100mb for after midnight along with BBC iplayer downloads. An unexpected pleasure was that I found P2P rates are great overnight and still ok if I need to finish a download off in peak time, under BB+ it was pretty much unusable.
I really can’t fault it as long as you can work around the 8gb peak limit.
25-03-2008 7:31 PM
25-03-2008 7:41 PM
I would have added to this sooner, but felt that the replies that you had received so far had covered all bases.
Anything in particular you want addressing?
26-03-2008 12:06 PM
I guess the thing that no-one's really addressed yet is my question about the constancy of the 1Mbps rate limit on download servers - i.e. should I pretty much always expect to see that rate between 4pm and 12am, or is it a bit more variable than that? (I ask as I understand that PN do fiddle with the rate limits during quiet periods etc.)
26-03-2008 1:05 PM
As you've alluded to, we would tweak these during quiet periods. I'll ask Tommo to give us some further info
26-03-2008 1:49 PM
It all depends on network load and how busy things are on any given day. As a general rule Sunday, Monday and Tuesday are the busiest days of the week and Friday and Saturday the quietest. Expect to see the rate limits at the rates on the portal on the busier days but on the quieter ones there is scope to relax some of them. We don't though relax every rate limit at the same time, so as the network gets quieter we might increase some of the BBYW 3/4 ones or Premier but not BBYW 1 and 2. Or do them in stages so first BBYW 3/4, then an hour later BBYW 2, etc.
One of the reasons I work late is so I can keep an eye on network performance like this so can make the changes on the fly so to speak as and when things happen. Tonight I expect to keep it at 1Mbps on BBYW 2 all night but depending how the network balances out tomorrow might get a bit higher after 10pm.
Plusnet Technology
26-03-2008 3:53 PM
