Connectivity Problems
- Re: Connectivity Problems
11-12-2007 9:53 PM
Over the last few months I have noticed my broadband connection going down on several occasions. Initially I used to do stuff like reboot my router (a Belkin), but it seems that I just have to wait about 10-15 minutes for it to sort itself out again irrespective of what I do. During that time it is constantly connecting and immediately disconnecting.
This happens probably once every couple of days, often in the early evening, but that might just be because that is mainly when I am using the internet, so wouldn't notice at other times.
What can I do to diagnose the fault? The phone line works correctly during this period. The only useful information I could glean from my router was the following firewall log during one of the disconnected periods...
12/11/2007 18:46:40 ADSL Media Up !
12/11/2007 18:43:19 ADSL Media Up !
12/11/2007 18:41:06 If(ATM1) PPP connection ok !
12/11/2007 18:41:05 ATM1 get IP:80.229.15.15
12/11/2007 18:41:03 ATM1 start PPP
12/11/2007 18:41:03 Dial On Demand(ATM1)
12/11/2007 18:40:13 ADSL Media Up !
12/11/2007 18:40:07 If(ATM1) PPP fail : Timeout in CHAP negotiation
12/11/2007 18:39:31 ATM1 start PPP
12/11/2007 18:39:31 Dial On Demand(ATM1)
12/11/2007 18:39:31 If(ATM1) PPP fail : Timeout in LCP negotiation
12/11/2007 18:39:31 ADSL Media Up !
12/11/2007 18:38:43 ATM1 start PPP
12/11/2007 18:38:43 Dial On Demand(ATM1)
12/11/2007 18:38:42 If(ATM1) PPP fail : Timeout in LCP negotiation
12/11/2007 18:38:42 Dial On Demand(ATM1)
12/11/2007 18:37:54 ATM1 start PPP
12/11/2007 18:37:54 Dial On Demand(ATM1)
12/11/2007 18:37:03 If(ATM1) PPP fail : Timeout in LCP negotiation
12/11/2007 18:36:13 ATM1 start PPP
12/11/2007 18:36:13 Dial On Demand(ATM1)
12/11/2007 18:36:08 If(ATM1) PPP fail : Timeout in LCP negotiation
12/11/2007 18:35:18 ATM1 start PPP
12/11/2007 18:35:18 Dial On Demand(ATM1)
12/11/2007 18:35:18 If(ATM1) PPP fail : Timeout in LCP negotiation
12/11/2007 18:34:32 ATM1 start PPP
12/11/2007 18:34:32 Dial On Demand(ATM1)
12/11/2007 18:33:49 If(ATM1) PPP fail : Timeout in LCP negotiation
12/11/2007 18:33:01 ATM1 start PPP
12/11/2007 18:33:01 Dial On Demand(ATM1)
12/11/2007 18:33:00 If(ATM1) PPP fail : Timeout in LCP negotiation
12/11/2007 18:33:00 Dial On Demand(ATM1)
12/11/2007 18:32:12 ATM1 start PPP
12/11/2007 18:32:12 Dial On Demand(ATM1)
12/11/2007 18:32:11 If(ATM1) PPP fail : Timeout in LCP negotiation
12/11/2007 18:32:09 Dial On Demand(ATM1)
12/11/2007 18:31:23 ATM1 start PPP
12/11/2007 18:31:23 Dial On Demand(ATM1)
12/11/2007 18:30:41 If(ATM1) PPP fail : Timeout in LCP negotiation
12/11/2007 18:29:51 ATM1 start PPP
12/11/2007 18:29:51 Dial On Demand(ATM1)
12/11/2007 18:29:50 If(ATM1) PPP fail : Timeout in LCP negotiation
12/11/2007 18:29:02 ATM1 start PPP
12/11/2007 18:29:02 Dial On Demand(ATM1)
12/11/2007 18:29:02 If(ATM1) PPP fail : Timeout in LCP negotiation
12/11/2007 18:29:01 Dial On Demand(ATM1)
12/11/2007 18:28:16 ATM1 start PPP
12/11/2007 18:28:16 Dial On Demand(ATM1)
12/11/2007 18:26:48 If(ATM1) PPP fail : Timeout in LCP negotiation
12/11/2007 18:26:48 Dial On Demand(ATM1)
12/11/2007 18:25:58 ATM1 start PPP
12/11/2007 18:25:58 Dial On Demand(ATM1)
12/11/2007 18:25:58 If(ATM1) PPP fail : Timeout in LCP negotiation
12/11/2007 18:25:57 Dial On Demand(ATM1)
12/11/2007 18:25:10 ATM1 start PPP
12/11/2007 18:25:10 Dial On Demand(ATM1)
12/11/2007 18:23:40 If(ATM1) PPP fail : Timeout in LCP negotiation
12/11/2007 18:22:50 ATM1 start PPP
12/11/2007 18:22:50 Dial On Demand(ATM1)
12/11/2007 18:22:50 If(ATM1) PPP fail : Timeout in LCP negotiation
12/11/2007 18:22:49 Dial On Demand(ATM1)
12/11/2007 18:22:02 ATM1 start PPP
12/11/2007 18:22:02 Dial On Demand(ATM1)
12/11/2007 18:17:31 If(ATM1) PPP fail : Timeout in LCP negotiation
12/11/2007 18:16:43 ATM1 start PPP
12/11/2007 18:16:43 Dial On Demand(ATM1)
12/11/2007 18:16:38 ATM1 stop PPP
The broadband fault checker doesn't report any problems either.
Any suggestions
thanks
Mark
Any suggestions
thanks
Mark
Message 1 of 7
(4,853 Views)
6 REPLIES 6
12-12-2007 11:04 AM
No suggestions for a solution, I'm afraid, but just to say I experience similar problems of occasional loss of access to the internet and mail servers at free-online. I connect through a wireless D-Link G604 modem, and this reports that both wireless access is OK and the DSL is connected. A reboot solves the problem. Problems mainly seem to occur late in the evening around midnight. I don't usually have the patience to see if access returns without a reboot if I wait long enough.
Message 2 of 7
(781 Views)
12-12-2007 1:25 PM
Do you know in you are on the tiscali LLU. I had this issue a long time ago, I also think there was a major issue with tiscali at this time as well. ANyhow it was all sorted when I was migrated back to BT product. Sorry about not offering a solution, but maybe another avenue to follow?
Message 3 of 7
(781 Views)
12-12-2007 1:44 PM
Visiting http://usertools.plus.net/@gateway will tell you if you are on LLU.
Message 4 of 7
(781 Views)
13-12-2007 12:49 AM
Quote from: jelv Visiting http://usertools.plus.net/@gateway will tell you if you are on LLU.
In my case this just says : You are currently connected to the "Telehouse East, Juniper 4" gateway. This gateway is sometimes known as pte-ag2. Is this BT?
Message 5 of 7
(781 Views)
13-12-2007 11:53 AM
You're on BT - LLU is THN-AG2
Message 6 of 7
(781 Views)
13-12-2007 2:08 PM
As above try all new filters in the phone points.
Try other routers too if possible.
Try plugging it into the BT master socket.
Message 7 of 7
(781 Views)
