Connections problems
- Re: Connections problems
26-06-2014 2:04 PM
Over the past few days my connection has been dropping frequently, it's having a bad effect on my connection I have connected into the Test Socket with an alternative microfilter (openreach could not fit a face plate easily on my socket) all ready to see if that would help.
Thanks Iain
Thanks Iain
Message 1 of 4
(521 Views)
3 REPLIES 3
26-06-2014 2:08 PM
Hi Iain,
When was it roughly that you connected to your Test Socket?
Here's a graph of your connection:
<img src="http://community.plus.net/visualradius/generated/image14037880377339.png"/>
Message 2 of 4
(336 Views)
26-06-2014 4:58 PM
Hi Chris
It was Sunday night that I connected to the test socket and changed the filter around 8 pm I think.
My connection is on 24/7 I never disconnect myself.
Thanks Iain
Thanks Iain
Message 3 of 4
(336 Views)
27-06-2014 9:55 AM
Thanks for the information. Please raise this with our Faults Team at http://faults.plus.net and we'll get this sorted out for you.
Message 4 of 4
(336 Views)
