Connection settings for new Belkin router
- Re: Connection settings for new Belkin router
25-08-2010 1:33 PM
I have bought a Belkin router and Plus Net is not on its list of ISPs. I was directed to a manual set up and I need to know the following, please:-
VCI
VPI
Encapsulated VCMUX ? or LIC ?
Whether
Static IP
Dynamic IP
PPPoE
PPPoA
PPTP
Many thanks,
Alex
VCI
VPI
Whether
Static IP
Dynamic IP
PPPoE
PPPoA
PPTP
Many thanks,
Alex
Message 1 of 8
(2,128 Views)
7 REPLIES 7
25-08-2010 1:38 PM
VPI = 0
VCI = 38
VCMUX
PPPoA
VCI = 38
VCMUX
PPPoA
Message 2 of 8
(1,610 Views)
25-08-2010 1:41 PM
& Dynamic IP (unless you ordered differently - you'd know if you did).
Message 3 of 8
(1,610 Views)
25-08-2010 1:52 PM
This Help & Support page accessed from the Member Centre provides confirmation of the information required and also provides links to additional information should you need it.
David
Message 4 of 8
(1,610 Views)
25-08-2010 3:07 PM
Quote from: itsme VPI = 0
VCI = 38
VCMUX
PPPoA
Thank you, but I have problems with logging on. Plus Net is rejecting my details????
I am not sure which user name to use. Is it "myname@plusdsl.net " or "myname@plus.com" ?
Thanks,
Alex
Message 5 of 8
(1,610 Views)
25-08-2010 3:09 PM
Alex - username@plusdsl.net
Message 6 of 8
(1,610 Views)
25-08-2010 8:19 PM
Hi, Guys,
Thank you very much for the advice and guidance. I have managed to connect and the new (factory reconditioned) Belkin router is working well.
Alex
Alex
Message 7 of 8
(1,610 Views)
17-05-2017 9:54 PM
Hi. do you still remember the settings fr your belkin router? thanks
Message 8 of 8
(1,551 Views)
