Connection problems have returned.
- Re: Connection problems have returned.
04-05-2021 7:52 AM
Our connection problems have returned.
The ADSL connection dropped 25 times over a 13 hour period yesterday.
It was stable overnight:
DSL Status @20:44, 03.05.2021 (system up time ~7 days)
Line State: UP [0x0]
Line Mode: G.992.5 (ADSL2+)
Line Uptime: 21m 18s
Annex: A
Profile: -
Data Rate: 8.787 Mb/s / 519 Kb/s
Max. Attainable Data Rate (ATTNDR): 21.116 Mb/s / 532 Kb/s
Latency: 0.25 ms / 0.25 ms
Line Attenuation (LATN): 14.1 dB / 6.5 dB
Signal Attenuation (SATN): 12.0 dB / 6.5 dB
Noise Margin (SNR): 24.3 dB / 11.6 dB
Aggregate Transmit Power (ACTATP): 18.3 dB / 9.9 dB
Forward Error Correction Seconds (FECS): 0 / 0
Errored seconds (ES): 47135 / 502
Severely Errored Seconds (SES): 857 / 23
Loss of Signal Seconds (LOSS): 17 / 6
Unavailable Seconds (UAS): 882 / 877
Header Error Code Errors (HEC): 1619356 / 9118
Non Pre-emptive CRC errors (CRC_P): 0 / 0
Pre-emptive CRC errors (CRCP_P): 0 / 0
ATU-C System Vendor ID: Infineon 113.200
Power Management Mode: L0 - Synchronized
DSL Status @ 07:45, 04.05.2021
Line Uptime: 34s
Annex: A
Profile: -
Data Rate: 10.725 Mb/s / 600 Kb/s
Max. Attainable Data Rate (ATTNDR): 21.504 Mb/s / 856 Kb/s
Line Attenuation (LATN): 13.5 dB / 5.9 dB
Signal Attenuation (SATN): 11.5 dB / 5.9 dB
Noise Margin (SNR): 21.8 dB / 14.4 dB
Aggregate Transmit Power (ACTATP): 18.3 dB / 12.7 dB
Errored seconds (ES): 47408 / 557
Severely Errored Seconds (SES): 977 / 24
Loss of Signal Seconds (LOSS): 27 / 8
Unavailable Seconds (UAS): 1206 / 1201
Header Error Code Errors (HEC): 2038349 / 10321
The quiet line test revealed noise (crackles) on the line.
Tried the telephone troubleshooter in the members centre, but it failed with:
"Oops, something seems to have gone wrong
It looks like something has gone wrong. Our award-winning support team are here to help.
Call us on 0800 432 0200"
Any suggestions?
The HEC errors seems to be going daft (122401 overnight and ~300000 in the last hour).
Regards,
Alistair
04-05-2021 8:24 AM
You clearly have a problem on your telephone line. The SNR has increased resulting in the speed drop to compensate. It is clearly the crackle that needs to be fixed before worrying about yoor speed, which is more than likely caused by the crackle.
Despite the troubleshooter message it's still possible that a fault ticket has been raised on your account. You need to log into your account and check.
04-05-2021 9:06 AM
@Baldrick1 Thanks.
Just off the phone to the help desk.
He has changed our settings from 'standard' to 'stable' and massively increased the latency on the connection:
DSL Status @08:50 04-05-2021
Line Uptime: 4m 13s
Annex: A
Profile: -
Data Rate: 21.921 Mb/s / 440 Kb/s
Max. Attainable Data Rate (ATTNDR): 21.980 Mb/s / 888 Kb/s
Latency: 5.50 ms / 8.0 ms
Line Attenuation (LATN): 13.1 dB / 5.9 dB
Signal Attenuation (SATN): 12.1 dB / 6.0 dB
Noise Margin (SNR): 6.2 dB / 26.5 dB
Aggregate Transmit Power (ACTATP): 19.9 dB / 12.7 dB
Errored seconds (ES): 47415 / 558
Severely Errored Seconds (SES): 983 / 24
Loss of Signal Seconds (LOSS): 33 / 8
Unavailable Seconds (UAS): 1431 / 1426
Header Error Code Errors (HEC): 2038363 / 10363
He asked me to switch the modem/router off for about a minute on Thursday afternoon, and said he will call back Sunday.
At less than 500m line length to the exchange on an EOL, we should not need to invoke interleaving. This is frustrating.
Good news: The call was answered promptly.
Regards,
Alistair
04-05-2021 9:29 AM
The agent has also reset the Noise Margin (SNR) to the default 6dB. If you still have noise on the telephone line then look out for this initially decreasing followed by an increase, along with a speed decrease.
It is interesting that your Upstream speed is only half that predicted. The upstream broadband frequencies are at the low end of the ADSL broadband band, which suggests that you could still have a high frequency 'hiss' on your line, be it a bit over the audio band used on the telephone system.
It will be interesting to hear if you get the call back on Sunday. Based on some of the reports on this forum I would not hold my breath!
04-05-2021 9:51 AM
The reset that the agent has done has probably capped the upstream, at the lower rate of 440Kbps. If there is noise on the line that needs to be addressed before any profile or snrm resets are done.
I would get back onto support and say you have a noisy phone line fault which needs to be fixed.
06-05-2021 1:55 PM
Good news!
Just had the 'faults team' on the phone:-
They have detected a fault on the line, and want to send an OR Technician.
I asked for a senior / multi discipline guy (with the better test kit) but that is not possible in the first instance.
There is a slot tomorrow morning so we can hope for an early resolution.
Regards,
Alistair
07-05-2021 6:16 PM
The BTOR guy was here this morning.
His tests reported a fault approximately 10m from the master socket. He checked the splice in the drop line on the house wall and found water ingress.
He fixed that and replaced the old GPO screw terminal just inside the window with crimps, retested and said it was much better.
Now waiting for Plusnet support staff to reconfigure the connection. Hoping they put it back onto fastpath.
DSL Status @2021-05-07 ~18:00
Line Uptime: 7h 11m 5s
Annex: A
Profile: -
Data Rate: 20.518 Mb/s / 888 Kb/s
Max. Attainable Data Rate (ATTNDR): 20.608 Mb/s / 888 Kb/s
Latency: 5.75 ms / 8.0 ms
Signal Attenuation (SATN): 11.7 dB / 5.9 dB
Noise Margin (SNR): 8.7 dB / 10.4 dB
Aggregate Transmit Power (ACTATP): 19.8 dB / 9.9 dB
Errored seconds (ES): 49019 / 558
Severely Errored Seconds (SES): 2572 / 24
Loss of Signal Seconds (LOSS): 62 / 9
Unavailable Seconds (UAS): 5618 / 5613
Header Error Code Errors (HEC): 1453605 / 10397
Last entry in my open 'question':-
Script User - Automated Script Pool
1:05pm, Friday 7 May 2021
Question [ nnnnnnnnn ] is now off hold. Our Support Team will provide a further update soon.
Regards,
Alistair
10-05-2021 7:40 PM
The Faults Team called earlier this evening to say that BTOR had reported the fault was fixed.
I was asked to monitor the connection for the next one - two weeks and to call back if it isn't stable.
I will reboot the modem/router in a day or two to get rid of those error numbers - they mostly accumulated before the repairs.
With any luck we will soon be back on a Fastpath connection...
DSL Status 2021-05-10 @~19.05
Line Uptime: 40m 37s
Annex: A
Profile: -
Data Rate: 19.161 Mb/s / 1.089 Mb/s
Max. Attainable Data Rate (ATTNDR): 19.172 Mb/s / 1.084 Mb/s
Latency: 6.25 ms / 1.25 ms
Signal Attenuation (SATN): 11.6 dB / 5.9 dB
Noise Margin (SNR): 11.4 dB / 6.5 dB
Aggregate Transmit Power (ACTATP): 20.1 dB / 9.9 dB
Errored seconds (ES): 49222 / 560
Severely Errored Seconds (SES): 2774 / 24
Loss of Signal Seconds (LOSS): 69 / 10
Unavailable Seconds (UAS): 5984 / 5979
Header Error Code Errors (HEC): 1453847 / 10408
Thanks,
Alistair
19-05-2021 4:21 PM
Looks like the target SNRM is still 12dB - you might yet get more out of this line.
19-05-2021 5:18 PM - edited 19-05-2021 5:36 PM
Thanks, I agree the connection should be able to improve. I was intending to leave about a week to see how stable it is.
The connection dropped in the early hours of Saturday morning but has been steady since. Attached is an extract from the log, along with the line status Saturday afternoon, and a few minutes ago.
I hope that we can be put back onto Fastpath (with the latencies reduced to 0.25ms each way, to keep our young game players happy).
Regards,
Alistair
Edit: Is is better to ask the Plusnet staff here , or on the helpdesk, for the settings update?
20-05-2021 10:59 AM - edited 20-05-2021 11:01 AM
Hi Alistair,
I'm sorry to see the connection issues have come back. Our tests aren't showing your upload speed to be capped but the SNRM target has shot back up to 12dB. I've put through a DLM change to move it down to 6dB.
Depending on how your line fares at this level, we can look at moving you back onto the Standard/Speed stability profile and potentially onto 3dB target. Let us know how it goes.
I've attached our testing below also if it helps further diagnose the issue (assuming there are still problems)
xDSL Status Check | |||
Circuit ID: | [redacted CBUK) | Service ID: | [redacted BBEU] |
Telephone NO.: | NA | Test Executed On: | 20-05-2021 10:46:16 |
xDSL Status Test Summary | |||||
Sync Status: | Circuit In Sync | ||||
General Information | |||||
NTE Status: | NTE Power Status: | PowerOn | Bypass Status: |
Upstream DSL Link Information | Downstream DSL Link Information | |
Loop Loss: | 5.8 | 13.0 |
SNR Margin: | 7.0 | 11.6 |
Errored Seconds: | 0 | 2 |
HEC Errors: | 0 | |
Cell Count: | 21314427 | 453049512 |
Speed: | 1096 | 19050 |
Maximum Stable Rate (KBPS): | 18176 | Fault Threshold Rate (KBPS): | 14541 | ||
Mean Time Between Retrains (Seconds): | 86400 | Mean Time Between Errors Upstream (Seconds): | 86400 | ||
Indicative Line Quality: | A | Mean Time Between Errors Downstream (Seconds): | 1653 | ||
Custom Thresholds | |||||
MTBR_RED: | MTBE_RED: | ||||
MTBR_GREEN: | MTBE_GREEN: |
From the picture below your connection certainly does look steady so far
Also I've run further diagnostics after the SNRM was changed to 6dB:
Upstream Link Info
Loop Loss | SNR Margin | Errored Seconds | Hec Errors | Cell Count | Speed |
5.8 | 7 | 0 | 0 | 8063049 | 1108 |
Downstream Link Info
13.1 | 6.1 | 0 | N/A | 36871252 | 22246 |
Downstream BIP Interface Data
Current Line Rate | Line Rate Change TimeStamp | Maximum Stable Rate Recalculated | Profile TimeStamp | Maximum Stable Rate | Fault Threshold Rate | Interleaving Flag |
18046 | 20/05/2021 10:48:02 | Y | 09/05/2021 05:27:09 | 18176 | 14541 | A |
20-05-2021 11:26 AM
Thanks,
The current downstream & upstream speeds are good. It will be nice to reduce the latency...
Current line stats:
DSL Status
Line Uptime: 10m 46s
Annex: A
Profile: -
Data Rate: 22.247 Mb/s / 1.109 Mb/s
Max. Attainable Data Rate (ATTNDR): 22.428 Mb/s / 1.104 Mb/s
Latency: 5.50 ms / 1.25 ms
Signal Attenuation (SATN): 12.1 dB / 5.9 dB
Noise Margin (SNR): 6.4 dB / 6.8 dB
Aggregate Transmit Power (ACTATP): 19.8 dB / 10.1 dB
Errored seconds (ES): 1452 / 6
Severely Errored Seconds (SES): 1452 / 0
Loss of Signal Seconds (LOSS): 6 / 1
Unavailable Seconds (UAS): 527 / 527
Header Error Code Errors (HEC): 148 / 26
Regards,
Alistair
20-05-2021 11:30 AM
21-05-2021 3:33 PM
I think the connection has been steady enough to move to the 'standard stability':
DSL Status ~15:30 2021-05-21
Line Uptime: 1d 3h 50m 10s
Annex: A
Profile: -
Max. Attainable Data Rate (ATTNDR): 22.372 Mb/s / 1.108 Mb/s
Noise Margin (SNR): 6.2 dB / 6.8 dB
Errored seconds (ES): 1454 / 6
Header Error Code Errors (HEC): 171 / 26
Regards,
Alistair
21-05-2021 4:31 PM
Thanks for the update Alistair.
Cool. After battling the system (Took a good few attempts, it must be sensing the weekend ahead) I've placed an order to move you onto standard stability now and it should go through on the 24th.
