Connection dropping out since thursday outage
- Connection dropping out since thursday outage
- « Previous
- 1
- 2
- Next »
Re: Connection dropping out since thursday outage
24-04-2012 11:45 AM
It seem's that the connection was dropping this morning but from what i gather this was done on purpose by the faults team doing checks on the line? well from what it looks like from the ticket response anyway. Should i be concerned that my SN margin (up) has gone from 6.5 to 32? i understand what the (down) does but what does the (up) do when it comes to margin? higher the number meant to be better?
Link Information
Uptime: 0 days, 1:15:35
DSL Type: G.992.5 annex A
Bandwidth (Up/Down) [kbps/kbps]: 440 / 16,983
Output Power (Up/Down) [dBm]: 12.0 / 0.0
Line Attenuation (Up/Down) [dB]: 8.5 / 19.5
SN Margin (Up/Down) [dB]: 32.0 / 6.5
Loss of Framing (Local/Remote): 41 / 0
Loss of Signal (Local/Remote): 5 / 0
Loss of Link (Remote): 0
Error Seconds (Local/Remote): 5 / 0
FEC Errors (Up/Down): NA / 4,617
CRC Errors (Up/Down): NA / 2
HEC Errors (Up/Down): 0 / 2
Link Information
Message 16 of 24
(466 Views)
24-04-2012 11:57 AM
That's the Up figure, the Down is 6.5
Just looked at the previous stats postings and I'd guess that your upstream has been capped as the speed has gone to 440, that's why the Upstream margin has changed, probably as a result of the drops, Shame we hadn't seen any more stats in between.
Have you tried another Filter and modem/router by the way? Had a quick glance through the thread and can't see it mentioned, sorry if I missed it.
When you do go to do swaps, good practise is to powerdown the modem/router first before disconnecting from the line.
Message 17 of 24
(466 Views)
24-04-2012 12:11 PM
Hey anotherone,
Yea ive tried a new filter but i don't have a new router to hand to test that. Strange thing is my connection just dropped again a few moments ago.. I don't really know whats going on with it, It's dropped a few times this morning also i was told. Really starting to get annoying.
Message 18 of 24
(466 Views)
24-04-2012 12:17 PM
When it drops, grab the phone and see if you can hear any audible crackling. Dial a 1 at it. If you need to listen for longer do the Quiet Line test on 17070.
Message 19 of 24
(466 Views)
24-04-2012 2:21 PM
Hi skib10,
I can only suggest seeing what the faults team come back with from your reply. I take it you are in the test socket?
Jojo
Jojo
Message 20 of 24
(466 Views)
24-04-2012 2:32 PM
I tried the test socket a few days back but the disconnects were still happening. Currently using the normal socket that ive always used.
Message 21 of 24
(466 Views)
24-04-2012 3:02 PM
Hi skib10,
I appreciate it might have dropped in there a few days ago but I imagine the faults team will be investigating under the impression it's in the test socket.
Jojo
Jojo
Message 22 of 24
(466 Views)
24-04-2012 3:09 PM
He hasn't got a spare router to test with, are you able to help there Jojo?
Message 23 of 24
(466 Views)
24-04-2012 3:36 PM
Possibly.
@skib10, if you put it back in the test socket for me and it's still dropping I'll see if I can arrange for another router to be sent out.
Jojo
Jojo
Message 24 of 24
(466 Views)
- « Previous
- 1
- 2
- Next »
