Connection dropping 3 days in row.
- Re: Connection dropping 3 days in row.
03-12-2011 8:42 AM
Link Information
Uptime:
0 days, 0:03:43
DSL Type:
G.992.1 annex A
Channel mode:
Interleave
Maximum Bandwidth (Up/Down) [kbps/kbps]:
1,132 / 7,520
448 / 7,488
Data Transferred (Sent/Received) [kB/MB]:
0.00 / 1.46
Output Power (Up/Down) [dBm]:
12.0 / 19.5
Line Attenuation (Up/Down) [dB]:
17.5 / 30.0
SN Margin (Up/Down) [dB]:
26.0 / 9.5
Vendor ID (Local/Remote):
TMMB / TSTC
Loss of Framing (Local/Remote):
0 / 0
Loss of Signal (Local/Remote):
65,539 / 0
Loss of Power (Local/Remote):
0 / 0
Loss of Link (Remote):
0
Error Seconds (Local/Remote):
65,539 / 0
FEC Errors (Up/Down):
0 / 0
CRC Errors (Up/Down):
0 / 0
HEC Errors (Up/Down):
0 / 0
No idea where this is starting at so hopefully some one can see something within this information.
Uptime:
0 days, 0:03:43
DSL Type:
G.992.1 annex A
Channel mode:
Interleave
1,132 / 7,520
448 / 7,488
0.00 / 1.46
12.0 / 19.5
17.5 / 30.0
26.0 / 9.5
TMMB / TSTC
0 / 0
65,539 / 0
0 / 0
0
65,539 / 0
0 / 0
0 / 0
0 / 0
Message 1 of 5
(1,110 Views)
4 REPLIES 4
03-12-2011 1:47 PM
Can't see anything amiss with those stats though it looks like the DLM has increased your target SNR margin to 9dB to try to stabilise the connection. Have you worked through the steps in the Dropping Connection troubleshooter?
If you have I suggest you raise a fault at http://faults.plus.net/.
David
David
David
Message 2 of 5
(489 Views)
03-12-2011 5:26 PM
Still getting connection drop outs, just had plenty full ! of disconnects.
DSL Connection
Link Information
Uptime: 0 days, 0:02:54
DSL Type: G.992.1 annex A
Channel mode: Interleave
Maximum Bandwidth (Up/Down) [kbps/kbps]: 1,188 / 7,424
Bandwidth (Up/Down) [kbps/kbps]: 448 / 7,392
Data Transferred (Sent/Received) [kB/kB]: 0.00 / 724.00
Output Power (Up/Down) [dBm]: 12.5 / 20.0
Line Attenuation (Up/Down) [dB]: 17.5 / 30.0
SN Margin (Up/Down) [dB]: 28.0 / 9.5
Vendor ID (Local/Remote): TMMB / TSTC
Loss of Signal (Local/Remote): 262,144 / 0
Loss of Link (Remote): 0
Error Seconds (Local/Remote): 262,144 / 0
FEC Errors (Up/Down): 0 / 1,958
CRC Errors (Up/Down): 0 / 0
HEC Errors (Up/Down): 0 / 0
jim:green formatted sorted to get rid of blank lines mod:end
DSL Connection
Link Information
Message 3 of 5
(489 Views)
03-12-2011 5:44 PM
Comparing the results from earlier today your error seconds have increased alarmingly.
Obviously there is something badly adrift
Does your router support Routerstats http://www.vwlowen.co.uk/internet/files.htm or Routerstats Lite
If it does can you start logging the data and see what happens when your error rate goes through the roof
Are you using the test socket - the one under the removable lower plate of the master socket
Message 4 of 5
(489 Views)
05-12-2011 9:26 AM
Hi dave1240,
Your line looked a bit unstable on Friday and Saturday, but seems to have improved. Is that because you plugged into the test socket?
Jojo
Jojo
Message 5 of 5
(489 Views)
