Connection and Speed
- Connection and Speed
10-10-2011 1:09 PM
My connection always used to work at 6dB. Now, everynight I get disconnections at 6dB. My setup hasn't changed at all. I have tried different routers and they all disconnect. I have a filtered faceplate on my master socket and I am connected directly to it. Is there anything Plusnet can do?
I am not at home at the moment so I can't give you any stats.
Message 1 of 9
(1,265 Views)
8 REPLIES 8
Re: Connection Not as Stable as it Was
10-10-2011 4:28 PM
Joanne, is it possible to run a check again on the line? Plusnet is now my phone providor by the way.
Message 2 of 9
(699 Views)
10-10-2011 4:32 PM
We'd need to ask that you raise a fault regarding any issues such as this, thanks.
https://portal.plus.net/apps/kbdfaults
Message 3 of 9
(699 Views)
10-10-2011 4:35 PM
Ok. I'll go ahead and do that.
Message 4 of 9
(699 Views)
11-10-2011 11:15 AM
Many more disconnections last night.
Message 5 of 9
(699 Views)
11-10-2011 11:38 AM
If the line is dropping connection then that definitely needs raising as a fault - if you run through the questions on the troubleshooter (the link Adam posted above) our faults team will pick this up and get it sorted for you.
Message 6 of 9
(699 Views)
11-10-2011 1:10 PM
Thanks Matt. I was just posting here so I can keep a log of what is going on.
I'll let you know if I have any problems.
Message 7 of 9
(699 Views)
17-10-2011 9:38 AM
I was wondering if one of the Digital Care Team could increase the profile at PlusNet's end? The profile is showing at 5500kbps on the BT speed tester.
Thanks.
Thanks.
Message 8 of 9
(699 Views)
Re: Connection and Speed
17-10-2011 3:47 PM
I loaded your account to update things for you, but it had already been picked up automatically - both profiles now matching at 5500
Message 9 of 9
(699 Views)
