Connection Status Graphy thing
- Connection Status Graphy thing
23-10-2012 11:53 AM
Howdy,
Can I see my recent connections graphy thing? I'm curious as to why interleaving has suddenly been activated on my line when its been running rock solid for 4 years.
Cheers,
A.
Cheers,
A.
Message 1 of 7
(1,229 Views)
6 REPLIES 6
Re: Connection Status Graphy thing
23-10-2012 12:58 PM
What's your username? You community site account is on a dial up account.
Kelly Dorset
Ex-Broadband Service Manager
Message 2 of 7
(630 Views)
23-10-2012 1:13 PM
Message 3 of 7
(630 Views)
23-10-2012 2:26 PM
Seen a lot worse!
Kelly Dorset
Message 4 of 7
(630 Views)
23-10-2012 3:00 PM
Cheers Kel,
that's what I thought it'd look like.
But still something caused the line to wobble enough for interleaving to be applied. Ah well, ticket has been raised to have it removed.
Message 5 of 7
(630 Views)
23-10-2012 5:10 PM
If as per your signature suggests, the physical link is dropping, but the existing PPP session is being maintained.
As such, the connection graph does not directly reflect what may be the source of DLM determining the need for interleave to be applied.
14 day analysis of the DLM data to midnight last night shows that the SNR margin downstream varies by 4dB from 7 to 11, with an average of 8dB. There is a current error measured on the upstream of the connection. Downstream it has seen errors as great as once average 8.6 minutes (on average over a 60 minute period), and once every 20 mins upstream (again, 60 minute average).
As this analysis only records to midnight last nigh, I cannot see how the current error it is displaying in realtime on the upstream is influencing the data on the DLM records.
Would be best rechecking tomorrow when todays data is associated into the 14 day history.
Message 6 of 7
(630 Views)
23-10-2012 5:19 PM
Cheers Phil.
If you want the numbers from the modem (Netgear DM111+), see below!
It's all Greek to me!
Cheers,
A.
> adsl info --stats
adsl: ADSL driver and PHY status
Status: Showtime Channel: INTR, Upstream rate = 832 Kbps, Downstream rate = 7616 Kbps
Link Power State: L0
Mode: G.DMT
Channel: Interleave
Trellis: OFF
Line Status: No Defect
Training Status: Showtime
Down Up
SNR (dB): 10.8 11.0
Attn(dB): 15.0 8.0
Pwr(dBm): 17.7 11.9
Max(Kbps): 9568 1104
Rate (Kbps): 7616 832
G.dmt framing
K: 239(0) 27
R: 16 16
S: 1 8
D: 16 2
ADSL2 framing
MSGc: 1 1
B: 255 27
M: 1 1
T: 1 1
R: 0 0
S: 1.0000 1.0000
L: 2048 224
D: 1 1
Counters
SF: 1507036 1507034
SFErr: 7 0
RS: 102478494 12809789
RSCorr: 482 4
RSUnCorr: 51 0
HEC: 5 0
OCD: 0 0
LCD: 0 0
Total Cells: 460186818 0
Data Cells: 15301029 0
Drop Cells: 0
Bit Errors: 0 0
LOF: 143 0
LOS: 11 0
LOL: 0 0
LPR: 0 0
ES: 47229 0
SES: 442 0
UAS: 215 0
Total time = 1 days 22 hours 46 min 35 sec
SF = 382780014
CRC = 18519
LOS = 11
LOF = 143
ES = 47229
Latest 1 day time = 22 hours 46 min 35 sec
SF = 4821951
CRC = 2169
LOS = 1
LOF = 13
ES = 51
Latest 15 minutes time = 1 min 35 sec
SF = 5605
CRC = 0
LOS = 0
LOF = 0
ES = 0
Previous 15 minutes time = 15 min 0 sec
SF = 52982
CRC = 0
LOS = 0
LOF = 0
ES = 0
Previous 1 day time = 24 hours 0 sec
SF = 5082378
CRC = 32
LOS = 0
LOF = 0
ES = 18
15 minutes interval [-30 min to -15 min] time = 15 min 0 sec
SF = 52923
CRC = 0
LOS = 0
LOF = 0
ES = 0
15 minutes interval [-45 min to -30 min] time = 15 min 0 sec
SF = 52923
CRC = 0
LOS = 0
LOF = 0
ES = 0
15 minutes interval [-60 min to -45 min] time = 15 min 0 sec
SF = 52923
CRC = 0
LOS = 0
LOF = 0
ES = 0
Cheers,
A.
Message 7 of 7
(630 Views)
