Connection Drops Part 2
- Connection Drops Part 2
Re: Connection Drops Part 2
06-02-2011 9:45 PM
Is my line banded or something because i cant get past 3.2mb i dont know how to imporve it, Am i on the right traffic management profile or whatever it is or is there anything on plusnests side of things thats wrong?
Also can i have my upstream back to 443 as i heard it can do more harm than good.
Becasue if i get a engineer out and he/she says its fine, then it must be something on your system as i have had the router in and out of the test socket since before christmas now and its getting beyond a joke.
cheers
07-02-2011 1:03 PM
One of the faults guys will call you about this shortly.
Jojo
07-02-2011 4:06 PM
Is there anything in my post above jojo? Upstream uncapped etc?
07-02-2011 9:40 PM
08-02-2011 12:38 AM
Just making sure as the the engineer is coming tomorrow
08-02-2011 9:00 AM
He showed me a little testing machine and it said that i should be getting 6.5mb as i have only and have ever had 4.0 max with plusnet.
He says i have interleaving on again too.
No problems my side of things so i dont know what to do now .
Lee
______
Update (9:25am) Just went off randomly again
08-02-2011 2:36 PM
Yes, I've just ran a check and the line has been banded. I'll get that lifted this afternoon and see how it goes. I'll let you know how it goes.
Jojo
08-02-2011 3:27 PM
Do this look ok ?
The maximum bandwidth number changes all the time is this right? i refresh the page and the maximum bandwidth (down) moves up and down
Link Information
Uptime: 0 days, 0:02:49
DSL Type: G.992.5 annex A
Maximum Bandwidth (Up/Down) [kbps/kbps]: 1,012 / 5,256
Bandwidth (Up/Down) [kbps/kbps]: 1,003 / 5,176
Data Transferred (Sent/Received) [MB/MB]: 1.44 / 7.53
Output Power (Up/Down) [dBm]: 12.5 / 19.5
Line Attenuation (Up/Down) [dB]: 28.0 / 46.0
SN Margin (Up/Down) [dB]: 6.0 / 6.5
Loss of Signal (Local/Remote): 65,538 / 0
Loss of Link (Remote): 0
Error Seconds (Local/Remote): 131,072 / 0
FEC Errors (Up/Down): 0 / 0
CRC Errors (Up/Down): 0 / 140
HEC Errors (Up/Down): 0 / NA
08-02-2011 3:37 PM
I don't know why it does that to be honest, it should stay the same. Once this banding is lifted I'll place an order to cap the upstream and we'll see if we can then get the best out of your line.
Jojo
08-02-2011 3:41 PM
08-02-2011 9:55 PM
I've just placed the order to cap the upstream and the banding should be lifted by now.
Jojo
08-02-2011 9:58 PM
im still having problems i dont know if FIFA 11 Comes into p2p traffic management or gaming traffic management ,wondering if pro would make a diffrence.
Thanks again jojo
Edit______
Did a reboot at 01:45 am still banded i think still on 3.2mb 800 upload
It looks good , just need the speed to back up the stats
Uptime: 0 days, 0:08:56
Maximum Bandwidth (Up/Down) [kbps/kbps]: 1,012 / 5,396
Bandwidth (Up/Down) [kbps/kbps]: 1,003 / 5,240
Data Transferred (Sent/Received) [MB/MB]: 6.11 / 26.33
CRC Errors (Up/Down): 32 / 11
HEC Errors (Up/Down): 7 / 37
09-02-2011 10:33 AM
it's not on our list of defined games but doesn't mean to say it won't be prioritised.
In that thread Dave suggests "If you are experiencing a problem with a specific game that isn't listed here, please raise a ticket confirming the name of the game, the port(s) that it uses and if possible (where applicable) the IP addresses of any central servers the game uses."
The banding's definitely been lifted otherwise your sync rate would not be as high as it is. We just need to be patient now and not reboot.
Jojo
09-02-2011 1:15 PM
But anyway, how long do i keep my router on for any changes to take effect.
Lee
09-02-2011 3:51 PM
