Connection Drops Part 2
- Connection Drops Part 2
Re: Connection Drops Part 2
12-01-2011 4:58 PM
12-01-2011 5:10 PM
Line Mode ADSL2+ Line State Show Time
Line Power State L0 Line Up Time 00:02:00:12
Line Coding Trellis On Line Up Count 1
Statistics Downstream Upstream
Line Rate 4543 Kbps 443 Kbps
Noise Margin 6.9 dB 17.1 dB
Line Attenuation 52.5 dB 28.3 dB
Output Power 0.0 dBm 12.9 dBm
MSGC (number in overhead channel data) 59 12
B (number of bytes in Mux Frame) 141 13
M (number of Mux Frames in FEC Frame) 1 1
T (Mux Frames over sync bytes) 1 4
R (number of check bytes in FEC Frame) 0 0
S (ratio of FEC over PMD Frame length) 0.9930 0.9912
L (number of bits in PMD Frame) 1144 113
D (interleaver depth) 1 1
Delay 0 msec 0 msec
Super Frames 446914 446912
Super Frame Errors 476 0
RS Words 0 0
RS Correctable Errors 0 0
RS Uncorrectable Errors 0 0
HEC Errors 255 0
OCD Errors 27 0
LCD Errors 0 0
ES Errors 0 0
Just looking at the noise level on my upload looks high is that normal for upload.
Again , thanks for your help jojo its appriciated.
13-01-2011 12:58 PM
When your profile lifts BT send us a delta report which then lifts the PN profile, when the PN profile lifts it triggers something called an administrative reset which basically reboots your connection.
Jojo
13-01-2011 2:50 PM
15-01-2011 9:49 PM
cant play online games properley since middle of december.
in the past ive had my router on for more than 72 hours for this BT profile thing to go up
I will bet anyone that not one thing will change in two days time when the 72 hours are up.
Im sure i actually pay for this and i get F all back.
EDIT: Not your fault (PN)i forgot to put in why BT do this in the first place its a joke.
17-01-2011 3:01 PM
Your upload speed is capped at 448k. I will uncap this for you.
Jojo
17-01-2011 3:17 PM
interleaving may of helped i dont know.
Router has been on 2 days 17 hours , do you rekon my profile will go up (BT Profile) is a day or so .
So bt will send you a report? as my PN profile is 4000 and bt is 3500
Thanks again
Lee
17-01-2011 3:35 PM
After more investigation it turns out that banding was applied which restricted the upload to 448k. I have lifted the banding and had the upload uncapped. This will take effect in the next few hours and you should also see a slight increase in speed. If the line is banded again we will have to try looking at why that's happening before it can be lifted again.
Jojo
17-01-2011 3:42 PM
Thanks for your help
Lee
17-01-2011 3:49 PM
thanks
EDIT____
Router restarted itself downstream gone up woo
Line Power State L0 Line Up Time 00:00:06:21
Line Coding Trellis On Line Up Count 2
Line Rate 5059 Kbps 443 Kbps
Noise Margin 6.1 dB 19.3 dB
Line Attenuation 51.5 dB 28.3 dB
Output Power 0.0 dBm 13.0 dBm
B (number of bytes in Mux Frame) 158 13
S (ratio of FEC over PMD Frame length) 0.9992 0.9912
L (number of bits in PMD Frame) 1273 113
Delay 0 msec 0 msec
Super Frames 23473 23471
Super Frame Errors 181 0
RS Words 0 0
HEC Errors 41 0
OCD Errors 2 0
LCD Errors 0 0
ES Errors 0 0
18-01-2011 2:34 PM
Did a speed test and nothing has changed at all
Line Power State L0 Line Up Time 00:07:05:50
Line Coding Trellis On Line Up Count 3
Line Rate 5539 Kbps 443 Kbps
Noise Margin 5.9 dB 20.0 dB
Line Attenuation 52.0 dB 28.3 dB
Output Power 0.0 dBm 13.1 dBm
B (number of bytes in Mux Frame) 173 13
S (ratio of FEC over PMD Frame length) 0.9993 0.9912
L (number of bits in PMD Frame) 1393 113
Delay 0 msec 0 msec
Super Frames 1573401 1573399
Super Frame Errors 55950 0
RS Words 0 0
HEC Errors 15302 0
OCD Errors 82 0
LCD Errors 0 0
ES Errors 0 0
18-01-2011 2:56 PM
It seems there is an inconsistency in what our systems say your upload is and what your getting from the BT systems. It's not a quick solution and if I have some time today I will take a look at it. Just bear with me and I;ll try to get it sorted for you.
Jojo
18-01-2011 3:15 PM
19-01-2011 1:20 PM
OK, I think I've sorted it. The uncapped upstream should take effect within the nest 24 hours.
Jojo
19-01-2011 2:47 PM
Line Power State L0 Line Up Time 00:00:24:38
Line Coding Trellis On Line Up Count 4
Noise Margin 7.5 dB 20.2 dB
Delay 0 msec 0 msec
Super Frames 91620 91618
Super Frame Errors 221 0
RS Words 0 0
HEC Errors 58 0
OCD Errors 0 0
LCD Errors 0 0
ES Errors 0 0
