Connection Dropouts
- Connection Dropouts
- « Previous
- 1
- 2
- Next »
Re: Connection Dropouts
19-01-2015 11:47 AM
You should try a single corded phone into the master socket (test socket is even better) next time this issue happens. Listen for a dial tone, if there's one there dial 17070 and do the quiet line test.
If you notice any problems with the phone line, report them to the phone provider and it's probably best not to mention broadband
Message 16 of 18
(218 Views)
19-01-2015 10:46 PM
Ive reported a fault to plusnet and I will do what you've said next time it happens Chris. I'm with BT but i'm thinking about moving to Plusnet which should make things a little less awkward
Message 17 of 18
(218 Views)
14-02-2015 1:00 PM
Have BT (your phone provider) fixed your PHONE line fault yet?
Is PN broadband now working properly again?
Message 18 of 18
(218 Views)
- « Previous
- 1
- 2
- Next »
